Hi nebie here!
  • 16 Replies
  • 3739 Views
Offline blacktrack
Hi nebie here!
« on: May 19, 2004, 01:28:51 PM »
Hi everyone. Great site. Been researching since sat. Glad to be a part.  My first zuk was an 89 zuk. It was rusted almost in half and I fell in love. They will go anywhere!!! Well now I have a 97 tracker. Almost ready to put some money in. Can't afford 3" susp. so I thought of 3" body, and sky coil spacers few questions. Will I need  shocks,struts? Will I have to do anything besides get alignment?  I DO NOT WANT TO TRIM, if possible ha,ha  I want 30x9.5x15 mtr's, Good size choice? What offset wheel would be best? Thanks for everyones help,again this site rocks!!
95XL7
Re: Hi nebie here!
« Reply #1 on: May 19, 2004, 01:37:07 PM »
Whats a nebie?? ::)
Offline blacktrack
Re: Hi nebie here!
« Reply #2 on: May 19, 2004, 01:56:06 PM »
Sorry i type fast.  NEWBIE- some type this label as being new to the site. I know its way off, but I need help before I buy and all my goodies don't fit. Anyone please help?
Offline 1bigtracker
  • 3409
Re: Hi nebie here!
« Reply #3 on: May 19, 2004, 02:00:37 PM »
what are you wheelin on?  on rock MTR's are the best(i hear)  and in mud i haven't been about to find any tire that can beat a swamper(TSL or Bogger)
stu
95XL7
Re: Hi nebie here!
« Reply #4 on: May 19, 2004, 02:02:41 PM »
Welcome BlackTrack, I was just being a smartass, i knew what you were trying to say.  ;)
Offline blacktrack
Re: Hi nebie here!
« Reply #5 on: May 19, 2004, 02:03:54 PM »
Wheelin in mud. Can I get a swamper in 30x9.5 radial that would wear out on the road in 15,000 miles? its also my only vehicle so it will be drove on the road alot.
Offline blacktrack
Re: Hi nebie here!
« Reply #6 on: May 19, 2004, 02:05:32 PM »
Again the king of typing errors.  I promise I will mess up in every post ; ;)
Re: Hi nebie here!
« Reply #7 on: May 19, 2004, 03:04:34 PM »
Who doesn't ;D
Welcome one and all..
Re: Hi nebie here!
« Reply #8 on: May 19, 2004, 05:24:43 PM »
Swamper Radials are a good long life tire
and still work very well in mud
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Hi nebie here!
« Reply #9 on: May 19, 2004, 05:37:11 PM »
These little rigs barely wear tires at all. My sister ran her radial swampers over 100,000 miles. Yep they were pretty bald, but you could still make out a pattern! I buy new tires every fall whether I need em or not. I drive about 40,000 a year. I have never got a set worn past half tread. Ive had a good history with the radial swampers and I highly recomend them to anyone looking to build a streetable wheeler.
Mike
BTW I do realize Im running the Goodyear Mtrs but thats only cause 35inch swampers are just too heavy for my little motor to pull down the freeway. In the smaller sizes its not noticable.
Offline blacktrack
Re: Hi nebie here!
« Reply #10 on: May 19, 2004, 06:13:01 PM »
WoW!!! 100,000 miles :o 30's will fit with a 3 inch body, and sky coil spacers. won't they? Without rubbing
Offline zukmon
  • 94
Re: Hi nebie here!
« Reply #11 on: May 19, 2004, 08:04:15 PM »
I ran a set of 30 x 11.50 Thornbirds for about 12,000 miles without hardly any wear (except gouges from the rocks). I had them at 17 psi on the street and about 9 psi on the trail. I went with Thornbirds because they are fiberglass belted and I commuted about 55 miles a day. They are a good compromise between a radial and a bias-ply tire. I've heard mixed opinions on them though, they are quite heavy, but wider than comparable height tires. I liked them better than my BFG Mud Terrains (33x12.50) or current Wild Countrys (33x12.50). I'm not sure how well they would fit on a Track/Kick. They worked great for me in mud, rocks, sand, dirt, and snow. I even won the 1997 AITC on them.
Re: Hi nebie here!
« Reply #12 on: May 19, 2004, 10:33:15 PM »
Welcome BlackTrack,
You should be able to run the 30's with the setup your wanting to do. I ran 29X10.50 Thornbirds for years when I only had a Calmini 2" suspension lift. The lugs would barely rub in the rear at full compression and factory bump stop location, and in the front at full turn and compression with no steering stop adjustment. Both rubs could of easily been fixed but it was so minimal that I never messed with it.
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
Re: Hi nebie here!
« Reply #13 on: May 20, 2004, 09:47:23 AM »
Hi and welcome.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Hi nebie here!
« Reply #14 on: May 20, 2004, 01:23:18 PM »
WELCOME TO THE BOARDS.............. LOOKS LIKE ALL BUT BACK SPACING WAS ADDRESSED.........ALOT OF FOLKS HERE SEEM TO RUN 2.5 BACK SPACING WHEELS IF I'M NOT MISTAKEN  .......IF THEY CHOOSE TO GET A NEW WHEEL ..........MATTY  8)
