Mounting a new custom bumper??
  • 2560 Views
« on: July 14, 2011, 05:47:19 AM »
I'm building a new bumper for my 87 sami, but I'm confused on how I should mount it. Can anyone send some pics or explain how you did yours?
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
Re: Mounting a new custom bumper??
« Reply #1 on: July 14, 2011, 07:31:11 AM »
I like your bumper  8) how about some more pictures of it, as you can see I still need to build a bumper, might have to copy yours :).
At the end of the frame rails there is four bolt holes, you will have to weld steel on the bumper that is in line with the frame, you will also have to cut a half circle out were the tubing that goes threw the frame sits. This is how I've seen most bumpers mounted. Red is the bolts going threw the frame rails, Orange is the mounting brackets welded to the bumper that sit in line with the frame rails, and Gray is the bumper. for more strength you could have brackets bolt on both sides of the frame rails insted of just one on each frame rail.
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
Offline my996duc1
  • 222
« Reply #2 on: July 14, 2011, 08:51:08 AM »
Not alot of different ways to mount a bumper on a Samurai.
Here is a step by step of how the Shrockworks bumpers install : http://www2.izook.com/?page_id=413
Some people also run U-bolts around the bumper tube and the frame tube on these. Of course, I reinforced the frame tube first since it is so thin.
Here is a pic from Shrockworks website to show where the u-bolts are installed.
« Last Edit: July 14, 2011, 09:06:44 AM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #3 on: July 14, 2011, 01:39:20 PM »
Here is mine...
I made brackets that bolt through the frame as described in the IZOOK page instructions.
