Gearing Possibilities?
  • 21 Replies
  • 5964 Views
Offline XEARLX
  • 62
« on: July 15, 2011, 05:41:24 PM »
whats up guys.
So i have these extra front and back axles im going to rebuild with new gears, shafts and hubs. Now my question is what gears should i put in the axles? i want the truck to be enjoyable to drive so something realistic would be nice. I know i want to do the HD 4340 chromoly front axle shafts but gear wise im uncertain with.
So through me some ideas and try to help me out if you can.
Thanks, Earl.
« Last Edit: July 15, 2011, 05:47:56 PM by XEARLX »
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: Gearing Possibilities?
« Reply #1 on: July 15, 2011, 10:20:57 PM »
what are we working on   ???
Offline XEARLX
  • 62
« Reply #2 on: July 16, 2011, 12:18:16 AM »
Why do you mean? I have both front and rear axles for an 88 samurai.
Offline my996duc1
  • 222
« Reply #3 on: July 16, 2011, 12:32:47 AM »
you looking for something to daily drive on the freeway / dual purpose / crawler ?
plug some numbers in here : http://www.grimmjeeper.com/gears.html
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline XEARLX
  • 62
« Reply #4 on: July 16, 2011, 12:37:47 AM »
Nagoya a weekend truck but I want it to be a good wheeler and a decent my climber
Offline Jluck
  • 1389
  • 40
« Reply #5 on: July 16, 2011, 12:21:22 PM »
what size tires are you planning to run? and whats your budget?would you prefer it to have a powerband like stock or maybe a bit higher geared for freeway travel? maybe lower geared for off road only? whats your intended use for the rig?
 t-case gears are a good option too.
Offline XEARLX
  • 62
« Reply #6 on: July 16, 2011, 03:04:52 PM »
Curently im sitting on 33's but i want to be at 35's easily and comfortable. like i said, its a weekend truck that im going to take wheeling and possibly climbing. i want it to be decent on the highway but great in the woods.
I was thinkin about buyin the 6.5:1 T-Case and not sure what gears to do in the axles. so this is where other people through in their two cents and let me know what they think.
Thanks guys
« Reply #7 on: July 17, 2011, 11:16:49 PM »
Worked on a Sammy with 35 MTRs  a set of 5.38 diffs and a 4:1
T-case, after all the work we went out wheeling and in my opinion
it wasn't low enough to crawl rocks, so you might go with a 6:1
T-case and 4.62 or 5.13 gears, tho 5.13s are going to be really low
with a 6:1
Offline XEARLX
  • 62
« Reply #8 on: July 18, 2011, 03:02:14 AM »
Yeah I was think a 6.5:1 t-case with 4.36 gears
« Reply #9 on: July 18, 2011, 05:51:46 PM »
Where are you going to find 4.36 gears?
If you want to use trackick gears for a swap, then your choices are 4.10, 4.62, 5.12, 5.38, 5.62.
Offline XEARLX
  • 62
« Last Edit: July 18, 2011, 06:17:32 PM by XEARLX »
« Reply #11 on: July 18, 2011, 09:08:02 PM »
I think that would be a good setup, run the numbers through
a gear calculator to see how that setup compares to the stock
gearing to get an idea where you will be
Offline XEARLX
  • 62
« Reply #12 on: July 19, 2011, 03:08:54 PM »
Yeah true. thanks man
« Reply #13 on: July 19, 2011, 03:12:27 PM »
they also have 4.30's from the newer rigs (99 and up) I know because I got a set from trail tough so I could drive on the street with the 6.4 t case.
Offline my996duc1
  • 222
« Reply #14 on: July 19, 2011, 04:22:57 PM »
I did the exact same thing.
4.30 gears with 6.4 t-case.
Has me spinning about 4000rpm at 65 mph and a decent crawl ratio of 100:1
