Steering Stabilizer
  • 1396 Views
Steering Stabilizer
« on: July 22, 2011, 06:06:23 AM »
My stabilizer imakes a lot creeks and groans.  I checked the FSM and the bolts on eack end (pivots) are soppossed to be tight 25ft-lbs or so not loose to allow the bush to slip.
My question is where is the slip really supposed to happen?  Will buying a new stabilizer fix this creek and groan problem.
94 sammy
Thanks
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Steering Stabilizer
« Reply #1 on: July 22, 2011, 02:12:55 PM »
Doubtfull that your stabilizer is actually making those noises. Start it up and have someone turn the wheel while you watch the stabilizer / front end to identify the source.
Otherwise pull the stabilizer and try to extend it. If it is in a bind or loose then yes replace it.
I am betting you will find the noise isn't from the stabilizer though...
