Sidekick tcase years
  • 2847 Views
Offline Bfunk
  • 406
« on: July 24, 2011, 10:13:13 PM »
I have a 98 tracker 2 door.  I'm just making sure that all the 89-98 transfercases are the same.  I would assume so but just thought I'd check to make sure.  Found one with gears and plan on swapping the whole thing. Thanks
Brian
Re: Sidekick tcase years
« Reply #1 on: July 24, 2011, 10:33:54 PM »
No, there are some slight differences, early 89-90 cases have slightly smaller (thinner)
gears, and is why the 4.24 gears do not fit into the case. The real difference is the
front cover, not the body of the case, but you might as well swap the whole case
There is also a version that has a different output spline count, some are 26 and some
are like 12 or 16, and have a square shape to the spline, like an American made spline
on a full size truck
Other than that, the gear ratios are the same, and the cases will interchange, but if
you want the lower gears or don't get the driveshaft from the lower spline count donor
you might have issues later
« Reply #2 on: July 25, 2011, 08:23:00 AM »
Brian
As wild said, the output shaft spline count changed in 96.  So you will need a tcase from a 96-98 trackick, to be a direct swap for yours.
Offline Bfunk
  • 406
« Reply #3 on: July 26, 2011, 09:49:25 AM »
So if I get both drivelines I should be fine.  thanks
Brian
« Reply #4 on: July 26, 2011, 09:52:25 AM »
Or swap yokes on the driveshaft, might as well put in some
good new joints too, stay with name brands or OEM
« Reply #5 on: July 26, 2011, 10:15:55 AM »
Brian
It is just the rear output shaft spline that changed.  All front output shafts are the same.  So you could either get the rear driveshaft, or just the slip yoke portion and put it on your rear driveshaft.
Offline Bfunk
  • 406
« Reply #6 on: July 26, 2011, 01:10:13 PM »
Sweeet thanks everyone
Brian
