1.6 liter swap needing guidance
  • 1988 Views
« on: July 26, 2011, 05:10:12 PM »
i am looking at swapping a 1.6 liter into my rig. i need to know what i need and dont, wether i go with the 8 valve or the 16 valve... PLEASE HELP!!
Offline rbparker
  • 120
Re: 1.6 liter swap needing guidance
« Reply #1 on: July 26, 2011, 06:11:40 PM »
You need a Suzuki Samurai.
You need a 1.6 block and don't need the 1.3 block.
You need tools and common car mechanic knowledge.
Just go 8v carburetor, you'd then only need the block, timing gears, tensioner pully, timing cover, and your current head. Then everything else I already mentioned in another of your threads.
I'm assuming you're not all that comfortable with car mechanics based upon your "tell me what to do" attitude. If not do the 16v its better in every way.
Lastly you need to search. Billions on people have posted everything you could ever want to know concerning everything you've posted.
Offline mrdezyne
  • 181
« Reply #2 on: July 27, 2011, 07:44:55 AM »
I'm going to pick up my 8v this week and begin the swap very soon.  I'm collecting info left and right and I'm finding out that depending on what donor 1.6 year model you have, different things are possible or need to happen.  The early model 8v is supposedly the easiest to swap but the 16v is the best bang for the buck and much better performance in high angle off road attitudes.
I'm saving bits and pieces of info and links in an outlook email format so if you want to PM me your email address I can send you the notes I have gathered so far.  you can read through it and get an idea of what needs to happen.  Once again most of my info is based on the 8v motor.
Offline mbruce
  • 139
« Reply #3 on: July 27, 2011, 08:15:55 AM »
« Last Edit: July 28, 2011, 06:54:29 AM by mbruce »
Ignorant questions lead to a wealth of knowledge
