Installing foot bridge with Tracker
  • 1617 Views
« on: July 31, 2011, 09:01:13 PM »
We are doing an upgrade to Silverarrow Bowman archery club, which includes new foot bridges.  I built a 40' long bridge (out of 6" pipe) to cross over a creek passing through the archery range, and used my Tracker to move the bridge into position.  After making my way through the trees and brush, I used the winch & snatch block to lift/drag the bridge across the creek.
Then winched it into place.
Then I had to try and drive out.
The work crew had to see whether I was going to get out.
It was a tight fit.
I did have to use my winch to get out, with all the humus I couldn't get enough traction to climb out.  Everyone was impressed with the abilities of the Tracker.
Re: Installing foot bridge with Tracker
« Reply #1 on: August 02, 2011, 01:40:18 AM »
We need to get better meat on those rims.  :)
« Reply #2 on: August 02, 2011, 05:50:51 AM »
It does need new meats, but just below the last photo it was probably as steep as I had in Moab, only in forest dirt it just dug holes.  I had it on two wheels when I was going down in.  I thought I was going to take out the mirror then also.
