new JS410 owner. clutch question
  • 1991 Views
Offline pbgbottle
  • 76
« on: August 02, 2011, 09:00:19 AM »
hey guys .just had my buddy's SJ410 given to me . it has been sitting for 5 years .
when i let the clutch out it comes up a bit .then it feels like it gets stuck or
 ex. goes over a hump then it will kick up at your foot and cause you to stall it as it jumps forward.
anybody have some ideas .  is something worn in side or put together wrong in the clutch
the cable seems to move freely .  anybody .   the clutch is just not smooth through the full clutch pedal cycle.
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Re: new JS410 owner. clutch question
« Reply #1 on: August 02, 2011, 10:26:05 PM »
That looks like a SJ-413 not a SJ-410.  Is the action smooth if you move the clutch manually?
Offline pbgbottle
  • 76
« Reply #2 on: August 03, 2011, 12:34:56 AM »
do you mean from below.    the rig is weird .dated 09/1984    .not sure if it is a crossover year or what
i am new to these rigs.
it has a t-case e-brake,   and i also needed to order wheel cylinders for the SJ410 .to work on this rear axle .
i thought it was a 413 also   but it uses differnt parts here and there .  i don't know what it is .
 but someone told me it may be the last year of the 410 mixed with the newer stuff also .  who knows.
anybody else      what years had the t-case e-brake?
thanks
4dr. auto
Calmini 6 inch
« Reply #3 on: August 03, 2011, 04:23:50 PM »
could be the clutch cable or the throw out bearing is dry where it slides on the trans snout, shoot some water in the timing hole. (rubber plug on trans).
« Reply #4 on: August 04, 2011, 12:26:22 PM »
replace the clutch cable, its 25 from napa
Zak
« Reply #5 on: August 06, 2011, 09:58:17 PM »
Someone must have swapped the front grill out.  But if it has a t-case e-brake then it's probably a 410.
Offline pbgbottle
  • 76
« Reply #6 on: August 07, 2011, 12:40:24 AM »
thanks guys ,i am still not sure what iti s  but it does have the ebrake t-case and the springs are also mounted narrower than the later samurai's
cheers i still have not checked the cable .   been busy .
4dr. auto
Calmini 6 inch
