Front thirds
  • 1612 Views
Offline mcs
  • 158
Front thirds
« on: August 15, 2011, 03:37:45 PM »
Does anyone know if a front third member from a 95 auto sidekick will fit into a 01 tracker. because I tried to switcf from a 4.62 to a 5.12 and the axle shafts are way different. Any help is appreciated
Offline Frank84
  • 176
Re: Front thirds
« Reply #1 on: August 15, 2011, 03:53:16 PM »
I know '96-'98 (26 spline) fit but I'm not sure about '95.  You need the inner axle shaft from the donor vehicle along with the right cv shaft.  You'll have to make a hybrid shaft that has the middle and outer part from your vehicle and the inner part that goes into the diff from the donor.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Re: Front thirds
« Reply #2 on: August 19, 2011, 06:35:15 AM »
89-95 fronts have 22 spline axle shafts.  In 96 they went to 26 spline front axleshafts.
Offline Uncivilized
  • 1469
    • Car Domain
Re: Front thirds
« Reply #3 on: August 29, 2011, 05:49:15 PM »
Does this mean it could be done if you used the 99+ side gears?
