Frame Repair
  • 2295 Views
Offline trackinstile
  • 435
Frame Repair
« on: August 19, 2011, 02:21:09 AM »
Just curious if anyone knows if there are any available replacement parts for the newer gen Tracker/Vitara frames. My upper drivers side shock mount is about half rusted through. I am planning on taking some quality time in the fall and cleaning up the under side and putting on some POR-15 paint. My guess is no, but if so could you point me in the right direction?  Thanks, Dave
Offline IanL
  • 466
Re: Frame Repair
« Reply #1 on: August 20, 2011, 12:21:00 AM »
Yes, they are available in the Suzuki Parts Catalog.
Bracket RR Shock Absorber Part# 57840-65D00
« Last Edit: August 20, 2011, 12:23:34 AM by IanL »
  • 435
Re: Frame Repair
« Reply #2 on: August 20, 2011, 06:34:50 AM »
FANTASTIC!!!  THANK YOU!!!!!
Offline IanL
  • 466
Re: Frame Repair
« Reply #3 on: August 22, 2011, 03:46:02 AM »
I omitted from the description that I quoted the one for the leftside:
Bracket RR Shock Absorber L Part# 57840-65D00
I believe RR means rear, because the front brackets are marked FR.
