1990 geo tracker
  • 2902 Views
Offline inchaos10
  • 162
1990 geo tracker
« on: August 19, 2011, 05:17:37 PM »
Im selling my tracker  :(. Its a 90 1.6 8valve just rebuilt again about 700 miles ago, has added power stearing, calmini 6" suspension, transfercase skid plate, 5.12 gears, mini spool in the rear. 31x11.5x15 super swamper ltbs on crager soft 8s with 4' baclspaceing. some scrub on the frame at full lock to the left. engine has phase 1 torquer cam from hawk strictly. Has new cv axles and a spare for each side. Its has a tinted soft top thats only 7 months old.
Some spare parts that are going to come with it are: 4.62 gears front and back, manuel stearing gear box, 8v head thats been decked and checked for cracks some scuffing where the cam lays, engine block that visably looks good, oil pump, water pump, oil pan, crank, piston rods, was basically a complete engine untill i tore into it to check it out. manuel  transmission fly wheel, intake, 2 map sensors, throttle body (2) i think, 2 injectors, A bucket of tracker bolt, egr valve (2) i think, high lift jack, and a spare transmission that was rebuilt but has bad oil pump, has new clutch packs inside (3 speed) At least i think its a bad pump. Also i might be able to include some complete rotor to rotor samurai axles. Dont know the year of them or anything. Ill double check on them and make sure they are still available.
the bad: needs passenger window regulator, small amount of rust around the window frame (passenger side), i think needs new driver side wheel bearing, i think thats about it.
If i think of anything els ill post it up. its located in florida right now but can get it to georgia if someone is really interested. Im asking 2,500.00
« Last Edit: August 27, 2011, 03:38:47 PM by inchaos10 »
Offline inchaos10
  • 162
Re: 1990 geo tracker
« Reply #1 on: August 27, 2011, 03:39:44 PM »
price drop. 2500
« Reply #2 on: August 29, 2011, 06:26:33 AM »
where in florida are you?
Offline inchaos10
  • 162
« Reply #3 on: September 03, 2011, 11:52:13 AM »
I live in Pasco county. dade city.
price is now best offer.
