what is it ?
  • 17 Replies
  • 5015 Views
what is it ?
« on: September 09, 2011, 06:49:16 AM »
There is a cylinder shaped gadget that is held onto the throttle body with a stamped steel
bracket with two screws.Has two wires and it plugs into the same harness as the tps.
Can anyone tell what this thing is ?
Still need a map sensor ! ;)
Re: what is it ?
« Reply #1 on: September 09, 2011, 08:55:13 AM »
Can you hum a few Bars?
Re: what is it ?
« Reply #2 on: September 09, 2011, 11:24:29 AM »
yeah it goes like this.
Re: what is it ?
« Reply #3 on: September 09, 2011, 03:44:59 PM »
The TPS wiring usually comes from the same plug as the injector wiring. What year is this, maybe its the Idle Speed Controller (ISC) - a pic would be good.
Re: what is it ?
« Reply #4 on: September 10, 2011, 09:23:02 AM »
Sounds like the ISC.
89/90 trackick, right?
Re: what is it ?
« Reply #5 on: September 11, 2011, 05:28:56 PM »
Thanks.
It is an 89.
And You could be right with the ISC,as idle is irractic and high.
I will try to get pics,I am not very good with that.
Randy
Re: what is it ?
« Reply #6 on: September 11, 2011, 11:04:19 PM »
A picture is worth .....
Re: what is it ?
« Reply #7 on: September 12, 2011, 06:03:12 AM »
Here is a pic... what's it worth?????
Sorry, could not resist...  :laugh:
Re: what is it ?
« Reply #8 on: September 12, 2011, 06:17:13 AM »
A couple more... does the part show up in these?
Re: what is it ?
« Reply #9 on: September 12, 2011, 06:34:02 AM »
I imagine this is what he is talking about.
Re: what is it ?
« Reply #10 on: September 13, 2011, 08:25:33 AM »
Thats it !
I am in the parts business,and spent all day looking for one,and can not even find a listing on it.
I friend in the bus. came up with an oe part # 96057985.
This is getting close to screwing up my upcoming 4-wheeling weekend!
Does anyone have one these ics's / icv's [some are calling it an idle control valve] that they are willing to part with.
I am willing to pay cash or barter with some engine parts.
Thanks
Randy
1-800-741-449six
Re: what is it ?
« Reply #11 on: September 13, 2011, 08:35:35 AM »
That is the idle up control, when you turn on the lights etc.
and I think it makes the rapid da da da da da noise when it's
active, heard it on my 89' from the very beginning. you don't
need it to run the Trucklet, so if you cant get one, don't let it
ruin your trip
Re: what is it ?
« Reply #12 on: September 13, 2011, 12:13:16 PM »
Call  Hawk... 1-888-SAMURAI.. they can ship you one out today...
Re: what is it ?
« Reply #13 on: September 13, 2011, 12:28:14 PM »
Thanks for the help.
Re: what is it ?
« Reply #14 on: September 13, 2011, 12:49:35 PM »
ruin your trip
WOW ! You you hit the nail right on the head.Since I first got the Tracker it has "ran" fine,but when you turn the lights on it would make that da da da da noise.FREAKED ME OUT! Once I was able to track down which piece was making this noice,I simply snipped the wires and the noice stopped and the engine stayed running.Seemed to run fine.In fact I have two outings on it since.
I became alarmed when I noticed the goo around the plug on my map sensor had melted and was running out like chocolate syrup.I began to think cutting the icv wires was causing this problem with the map sensor.
If I can run without the icv,that would be great , but then I still have the issue of an idle goes up and down when I first start the engine,and then seems to remain high.
Thanks
Randy
