WTB: Samurai Tcase parts
  • 2414 Views
Offline mrdezyne
  • 181
« on: September 15, 2011, 09:06:59 AM »
I"m looking for either a complete tcase that is good for parts - OR - specifically an output shaft, shift collar, and 4wd shift switch.
pics of items needed below.
« Last Edit: September 15, 2011, 10:50:07 AM by mrdezyne »
Offline tipover
  • 422
Re: WTB: Samurai Tcase parts
« Reply #1 on: September 15, 2011, 09:59:01 AM »
Pics shown are output shaft and clutch.  I have both if ur interested. Ill check for switch.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline mrdezyne
  • 181
« Reply #2 on: September 15, 2011, 10:51:30 AM »
i was just going by what the Trail Gear install instructions called them.  Yes I'm interested if they are in better shape than these, thanks!
Offline tipover
  • 422
« Reply #3 on: September 16, 2011, 04:49:28 PM »
I have the shaft and shift collar.  It is hard to see in the pic, but is the issue with your shaft rust and pitting on the bearing surfaces?  The cog on your shaft that the collor locks to has some wear on it but that is common and not a problem on the high range side.  My shaft also has some wear but not as bad as yours. make offer. I do not have a good shift light swtch.  Oh is that shift collor for the front output or the high/low?
« Last Edit: September 16, 2011, 04:51:29 PM by tipover »
Offline mrdezyne
  • 181
« Reply #4 on: September 19, 2011, 08:10:25 AM »
The shift collar is fit between the high and low speed gears.  Are the collars different?  they seemed to be interchangeable when I was looking at mine...
the shaft is heavily pitted, doesn't seem to be rusty but it is worn beyond repair and the new bearing will wear out prematurely.  if you click on the photo it will open into a much larger shot that does show the pitting pretty good... I really need a shaft with a good bearing surface if possible.  can you send me or post a pic of the bearing surface?
thanks for checking, i really appreciate it.  This tcase is just sitting in pieces until I find these parts..
Offline tipover
  • 422
« Reply #5 on: September 20, 2011, 09:41:44 PM »
I wont be home the rest of the month for work. I really dont want to tear the cluster apart unless we got some deal. It is in great shape.
Offline mrdezyne
  • 181
« Reply #6 on: September 21, 2011, 09:20:07 AM »
I think I have the parts sourced.  Don't worry about parting it out if its in good shape but thanks anyway!
