My TN_Tracker-styled tailgate rack and PVC snorkel
  • 2778 Views
Offline explosivo
  • 3157
« on: May 16, 2004, 06:36:08 PM »
So I had some free time today, which I decided to spend on making some stuff for the Tracker.
First up is my TN_Tracker-styled tailgate rack. It's not a direct copy, since I don't keep a spare on the back, but rather cut the spare tire mount off and left about 1" of metal sticking out, which I welded the rack to. Here are some pics:
I can carry a gas can or a cooler, if I find one that is small enough to slip inside the angle pieces:
I also made a snorkel out of PVC pipe and some of the rubber fittings that came on the airbox of the Tracker. I'm going to add a little tube on the outside curly part where it goes into the fender with a drain plug in the bottom to attempt to catch any moisture that gets sucked in.
I still have to paint it/coat it with something and fix up the hole that I made in the fender to look a little better than it does now.
This is a mock-up from earlier in the day... the finished tube isn't that long (it's about 8" shorter):
More pics: http://www.eye-irritant.com/gallery/index.php?album=Tracker+Shiz%2Fsnorkelandrack&sortby=name&order=asc
omghi2.us[/url]
Offline 1bigtracker
  • 3409
Re: My TN_Tracker-styled tailgate rack and PVC sno
« Reply #1 on: May 16, 2004, 11:37:59 PM »
looks like the evil seed is growing well with you.  ;D
stu
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: May 17, 2004, 11:01:21 AM »
Now on deep water crossings you will have to be carefull that YOU dont drown.  ::) The zuk should be fine. ;)
Mike
Offline Mike71
  • 1449
« Reply #3 on: May 17, 2004, 11:03:56 AM »
lookin good dude...whats with the ratchet strap though?
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #4 on: May 17, 2004, 11:28:02 AM »
LOOKS GOOD EXP. NOTHING BETTER THAN A LITTLE HOME MADE SNORKEL TO GET YOU THROUGH THAT BIG MUD HOLE NEXT TIME  ;D WHAT YOU DOUNG FOR THE DISTRIBUTOR  ???   MATTY  8)
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #5 on: May 17, 2004, 11:30:51 AM »
Nice to see my rack was an inspiration for you.
Question though, where's your spare?
  • 2274
« Reply #6 on: May 17, 2004, 11:36:32 AM »
FROM THE LOOKS OF IT ITS LIKE MINE , NON EXISTANT  :-[  MATTY
Offline explosivo
  • 3157
« Reply #7 on: May 17, 2004, 02:58:47 PM »
I broke the body mount bolt on that sied, and a ratchet strap is much easier to use than fixing it right ;)
My spare I throw in the back, since it's not fullsized and looked funny on the tailgate. :)
I painted it today but didn't take any pics yet... looks pretty slick, IMO. Much better than the white PVC.
« Last Edit: May 17, 2004, 03:00:32 PM by explosivo »
omghi2.us[/url]
