Jx tach into non jx not working
  • 1861 Views
Offline Twarlick
  • 6
« on: September 18, 2011, 05:39:56 PM »
I got a jx cluster from a buddy of mine but it isn't working at all, only the gas hand. I'm not sure if I am needing to so something else or if the cluster is just bad. All the plug up hooked right up so I really not sure. Any help would be great. Thanks
Re: Jx tach into non jx not working
« Reply #1 on: September 18, 2011, 08:53:17 PM »
Should be plug and play.
I am guessing the cluster is from an 86-88 samurai (yellow gauges)?  And you are putting it into an 86-88 samurai?
Whether or not the plugs plug right in is irrelevant.  All samurais from 86-95 have the same plugs.  But the wires are not laid out the same in all of them.
Offline Twarlick
  • 6
« Reply #2 on: September 19, 2011, 12:33:55 PM »
My sami is a 86 I have no clue what year gauges they are the are black background white needles yellow numbers I don't know it that helps.
« Reply #3 on: September 19, 2011, 06:09:42 PM »
Yeah, that is the 86-88 style of gauges.  So it should be plug and play into yours.  I'd say the cluster is bad.
« Reply #4 on: September 23, 2011, 08:06:02 AM »
It should work with yours check the wires to make sure everything is plugged in good. Its prolly a bad cluster
Zak
