Sidekick Diff welding
dumpkofp
September 19, 2011, 06:25:56 AM »
I have read the articles on installing a mini spool. What I want to know is can the rear Diff be welded? If so...
How?
mrfuelish
2862
13
you must have a perception problem.
Re: Sidekick Diff welding
September 19, 2011, 09:42:56 AM »
your Better off with the spool, my welded diff on my samurai lasted about three trips out and when it went it took out everything with it.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
Drone637
8121
116
Evil Cow
September 19, 2011, 02:57:05 PM »
The spool is cheap insurance to make sure the welds don't break. As for how to weld up the gears, just like you would on any other rear end. Put it in the oven for a while to bake the oil out and raise the temperature of the metal. Then weld away.
kreator
634
15
Reply #3 on:
September 27, 2011, 04:25:00 PM »
Lincoln lockers is not what you want, its cheap but will cost more in the long run .
BOB |
www.KreationFab.com
| 503-689-1377
ack
1659
34
Professional askhole
Reply #4 on:
September 27, 2011, 05:09:07 PM »
I have to agree with the above. Lockrites or similar, a Spool or - if you can afford them, ARB lockers are a better choice.
That said, here is a link to a "Fozzy Locker" welding article at Ack's FAQ that apparently resulted in a strong, long-lasting welded unit:
http://www.acksfaq.com/fozzylocker.htm
Again, the only advantage to this is that it is a cheap mod. I personally do not reccomend it. I hope your welds are good!
Ack
Ack's FAQ
zuki1018
397
7
Reply #5 on:
October 01, 2011, 02:47:17 PM »
I will triple the agreed negatives on the welding. Its no 5 minute task removing a 3rd. Sure wouldn't wanna do again if it gives out. I waited till my funds allowed and went lockrites front/back. I also replaced every seal and bearing since everything was apart. Been very satisfied and the unlocking click is nothing to what I expected from reading.
My front was welded unbeknownst to me until I had to replace a broke pass. Axle and hub!! Sure as hell was a beast turning in 4x4 too! Let us know which Way u go.
igofshn
13
Reply #6 on:
October 02, 2011, 08:37:04 AM »
My Sammy has been Fozzy Locked for a very long time. It works great. Welding the diff is not rocket science. Failed weld ing is usually caused from over heating. Just weld the side gears.
