Pinion input rotation
  • 2081 Views
« on: September 20, 2011, 04:09:54 PM »
My dad used to own an 85 Samurai. He is looking into some parts for a project and would like to know what the pinion input rotation for the axle when it is moving forward. If that makes any sense. Any help would be appreciated. If I was unclear let me know.
Re: Pinion input rotation
« Reply #1 on: September 20, 2011, 06:20:16 PM »
You want to keep it at the stock angle.  If you are going to rotate the pinion then you need to cut off the knuckles and re-align them at the same time or front end alignment is going to go to pot.
« Reply #2 on: September 20, 2011, 09:55:17 PM »
Same as the engine rotation, clock wise as you look at it,
the only odd ball I know of is Honda, rotates CCW
« Reply #3 on: September 21, 2011, 09:28:24 AM »
Ah, pinion input rotation...  I was way off.
« Reply #4 on: September 21, 2011, 07:14:13 PM »
No worries, it was good advise for an axle rotation  :)
« Reply #5 on: September 22, 2011, 04:48:14 AM »
Thanks for the input - no pun intended!
