Home made gas tank skid plate I made
  • 2844 Views
Offline zuki709
  • 190
  • 6
« on: September 22, 2011, 08:00:46 AM »
Here is a Gas tank skid plate I made a couple of years ago for my 01 tracker. It is made of 1" square tube, old bad rails angle for mount, And 1/8" Diamond plate.
pics of the frame
Pics of the plate welded before mounting to frame
Painted and assembled
installed on tracker
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
Offline samuraidan
  • 196
  • speak softly, and carry a big stick
    • City Ranger
Re: Home made gas tank skid plate I made
« Reply #1 on: September 22, 2011, 08:13:48 AM »
That thing looks pretty heavy duty. Did you remove the factory skid plate before installing?
'00 Vitara 2.0L 5spd w/ Jeff's lift, SR Customs body lift, 5.13's, rear locker, SR Customs steel pinion collar, 1.25" wheel spacers, 15x7, 31x10.5R15 Dynapro MT's.
Offline zuki709
  • 190
  • 6
« Reply #2 on: September 22, 2011, 08:27:24 AM »
yes i took the old skid of drilled the hole in the angle and mount them where the old skid was mounted. Then I made the bottom  part of the frame put it on blocks so it sat at the right hight pieced it together from there. That is what took the most time because of all the turn. And yes it is heavy duty I jack up the back on the skid when ever I work on the rear.
Offline tcfootball
  • 82
« Reply #3 on: September 23, 2011, 09:15:48 PM »
Sweet!  Bed railing is good for tons of uses!  I made a bracket for my CB whip out of it.
