wiring help
  • 1580 Views
Offline blackpearl
wiring help
« on: May 15, 2004, 05:26:23 PM »
need help wiring a 1.6 into a sammy, every thing else installed just wiring left to do need the important wires and what wires can disapper.
Re: wiring help
« Reply #1 on: May 16, 2004, 04:40:59 AM »
Is your 1.6 a 16valve or 8 ???
Is it going to be Injected or Carb ???
If you are going the Injected route you
will need the ECM, then take all the sensor
wires and lead from the Distributor, don't
forget the Electric fuel pump to make the EFI
work, it also has a conrol circuit to cut the pump
off when the engine fails to start, or stalls.
Good Luck
