stock 4dr sidekick spring rate... Does anyone know?
  • 3453 Views
« on: October 10, 2011, 11:24:22 PM »
 I am looking for a slight lift for the rear of my 4dr sidekick and I was wondering if xl7 springs would provide the extra inch I am looking for.. also I am thinking about ordering aftermarket springs and I was looking to see if anyone knew what the factory spring rate was so i can get the same as stock.. thanks in advance.
Re: stock 4dr sidekick spring rate... Does anyone know?
« Reply #1 on: October 14, 2011, 03:06:16 PM »
SWB front - 227mm x 83mm 452.8lbs/in
SWB rear - 250mm x 83.7mm 156.5lb/in
LWB front - 227mm x 83mm 508.7lb/in
LWB rear - 250mm x 83.4mm 173.4lb/in
Offline Zuki-Girl
  • 128
« Reply #2 on: October 19, 2011, 02:55:37 PM »
Sorry to break in on this one. But can the coils from a 4 wheel drive 4dr Kicker be used on a 2 wheel drive 4 dr kicker?
« Reply #3 on: October 19, 2011, 07:11:11 PM »
Yes, they usually give an inch or so of lift.  Depending on the condition of the springs.
  • 6603
  • 69
« Reply #4 on: October 20, 2011, 06:57:11 AM »
Hey Rhinoman - These are very precise numbers. Did  you measure this or find this info in a book/manual? I've been looking for and have had this type of info in the past but recently I was looking for the numbers and couldn't find them. Anyway, I was just interested in the source so I can save the money vs. going to a speed shop and measuring some stock springs on a tester... :)
Thanks, Eric
« Reply #5 on: October 21, 2011, 01:24:52 AM »
I usually go to Low Range Off-Road and get the numbers from the OME lift springs section.  :P
« Reply #6 on: October 21, 2011, 02:52:22 PM »
Thanks, Eric
I got them from the Suzuki Specs that they submitted for type approval. PM me an email address and I'll send them too you.
  • 6603
  • 69
« Reply #7 on: October 23, 2011, 10:29:41 AM »
Thanks, Eric
That's sounds good. They must be metric to SAE/Imperial/English conversion artifacts on how they get the .7 of a pound
