93 4door suzuki sidekick
  • 1733 Views
Offline airmanwilliams
  • 913
« on: October 12, 2011, 09:30:45 AM »
93 suzuki sidekick jx 4door-located near salt lake city
$6000 or trade for a couple of good  sidekicks so I can have one to drive and have one to replace my wifes crappy dodge neon as well.
Parts not installed but included: spare radiator with fan shroud, brand new manual hubs, 5spd trans with tcase and ott kicker 1 doubler setup along with stock samurai tcase, spare hood, 85 toyota full rear axle with 4.10 axle gears, brand new clutch disc and pressure plate.
Rebuilt 1.6 16v SOHC motor. [work done at Cleggs auto.]
Rebuilt Head, all new valves seats etc [work done at Warrens in Spanish fork. ]
Full Calmini Exhaust and headers
Calmini 3" Suspension Lift with 3" articulation lift and 2" body lift. Can run 33s without trimming
Calmini differential Drop Brackets
Recently tuned up Iridium plugs, Cap, Wires, and Rotor installed after rebuild.
CD player
NEW Stabilizer links
NEW Shocks
NEW Struts, Strut mounts
NEW EGR Valve
NEW Tie Rods [all around]
NEW ball Joints [All of them]
Calmini Drop Brackets
Upper Rear Ball Joint Spacer
NEW Front and Rear Brakes
NEW Vacuum Control Valves
NEW Valve Cover Gasket
New Timing Belt, Tensioner and Timing Cover
Custom Steel bumpers front and rear
Gas Tank has a Skid Plate.
Installed 5.625 Gears to match the 31" tires [$1000 gears if you can even find them] Speedo is dead on and the low range is lower than most 4x4s . These gears can handle up to 33 tires without killing low range gearing and highway driving.
Motor and head has less than 11K on them. Car has 156K
« Last Edit: November 15, 2011, 05:23:10 PM by airmanwilliams »
1993 4door Suzuki Sidekick JX
  • 913
Re: 93 4door suzuki sidekick
« Reply #1 on: November 15, 2011, 05:23:21 PM »
bump.
