WTB- hood and pass side fender
  • 2507 Views
Offline unbridled
  • 33
« on: October 15, 2011, 06:41:45 PM »
I'm lookin for a hood and passenger side fender.  Daughter had a bit of a misshap... :(
59725
Offline unbridled
  • 33
Re: WTB- hood and pass side fender
« Reply #1 on: October 17, 2011, 04:50:07 PM »
I wonder if a Sidekick hood can be made to work.  I just want to get it back on the road for now.
« Reply #2 on: October 18, 2011, 06:16:24 AM »
A sidekick hood isn't even close to the same shape.  I'd just run it without a hood, before I'd try to get a sidekick hood to work.
Offline unbridled
  • 33
« Reply #3 on: October 18, 2011, 05:48:08 PM »
Yeah, I'm just lookin for something close until I find a Sammy hood.  Looks like they are too shallow.  Might just try flat sheet metal and bend it likr I need it,
Offline jzap
  • 515
  • How difficult can it be?
« Reply #4 on: October 21, 2011, 05:57:28 AM »
When I whacked an 8 pointer and couldn't find a hood for a while, I just laid mine on the ground and stomped it back into roughly the right shape. Take the hood latch off and bolt the hood back on the truck. Then I unscrewed the rubber stops and replaced them with a long bolt and cut the bolt heads off to make them into studs.  I drilled holes in the hood at the stud locations so they passed through the hood.  Then I put big washers on top, drilled a hole in the stud and put a spring clip through the stud to hold the hood closed.  It was like the hood pin kits that hot rodders used back in the '60's.  It got me through the winter until I found another hood...
Jim Z.
66 Apache camper
« Reply #5 on: October 24, 2011, 04:39:39 AM »
where are you located I am in Oklahoma I should have what you need
Offline unbridled
  • 33
« Reply #6 on: October 24, 2011, 07:34:08 AM »
I'm in Montana 59725
Offline unbridled
  • 33
« Reply #7 on: October 24, 2011, 07:36:06 AM »
Yeah, I was considering that.
