93 4X4 Tracker automatic tranny sticking in first on cold mornings
  • 2624 Views
Offline longarch
  • 61
I have a 1993 4X4 Tracker that is in great condition but has developed a problem with the automatic transmission staying in first gear until the fluid or something begins to warm up. It immediately goes into first directly after cranking but as season changes and the outside temperature cools down is taking longer to change to second gear. It will even slip as in neutral until something warms up. Once it changes from first to second it shifts up and down without hesitation. What do you think mechanically is my problem and what I should do to solve that problem.
'94 Tracker W/Hard Top
1.5" Front Coil Spacers - 2" Rear Coil Spacers - 2" Strut Spacers
30x9.50x15 Cooper Discoverer STT's
Calmini Front & Rear Tube Bumpers
Bored 30 Over & Head Shaved
Swapped 4:42 gears for 5:12's
Offline longarch
  • 61
Re: 93 4X4 Tracker automatic tranny sticking in first on cold mornings
« Reply #2 on: October 20, 2011, 06:10:29 PM »
....found a Gennie in a bottle.....
http://bbs.zuwharrie.com/content/topic,119008.0.html
« Reply #3 on: October 20, 2011, 06:12:28 PM »
Yeah, I've heard that sometimes works too.  Glad it worked for you.
Offline longarch
  • 61
« Reply #4 on: October 20, 2011, 06:51:35 PM »
I still appreciate you input and effort Skyhiranger. It means a bunch that you take the time to try and help greenhorns such as I.
Jeff
« Reply #5 on: October 20, 2011, 06:56:02 PM »
Jeff
No problem.  I was just pointing you in the direction of a possible fix, based on my experience.
« Reply #6 on: October 25, 2011, 10:42:51 AM »
I had my trans rebuilt 10 years ago. The shop told me the seals were so dryed out they came off in pieces. It sounds like the same thing your are doing and gets progressivly worse over time. Mine started acting up in the winter and by he time I got it in to the shop to have it fixed would have to drive almost two miles before 2nd would kick in.
