2.o belt replacement
  • 1542 Views
Offline RifleRide
  • 29
  • Mentor a Child!
« on: May 13, 2004, 03:22:34 AM »
"Give me suggestions on how to replace belt on 99 tracker.  Tensioner pulley does not seem to be working properly when wrench is applied"
Offline jagular7
  • 1026
  • Jagular7
Re: 2.o belt replacement
« Reply #1 on: May 13, 2004, 04:06:29 AM »
Only thing I can suggest is that you rotate the pulley bolt and not the bracket bolt. I made this mistake once. Got the belt off, but then had a real problem getting the belt back on same way I took it off. DOH!!!
Use a breaker bar with proper size socket and rotate it opposite of the belt. This should work.
Lenexa, KS
