Trail tough trail slayer coil kit
  • 4953 Views
Offline Kazang8272
  • 9
« on: October 25, 2011, 02:22:25 PM »
I'm looking to put together one of these buggies got some toy axles and a bare frame, anybody got some time with this I've read all trail toughs info and scence there pics looks aight
1988 Samurai spoa, 1.5 in spring lift, sidekick thrids, 4.16 trans reduc, 33 in procomps
1990 Samurai pretty stock still
2003 Toyota Tacoma 6 in pro comp lift, 35 in bone crushers, 5.10 thirds, dc 2 wheels
Re: Trail tough trail slayer coil kit
« Reply #1 on: October 25, 2011, 09:34:35 PM »
I have seen them in person at their shop a few times and I must say that that is a top notch set up, I don't think you would ever find a better set up from a vendor.
Offline ToyYoda
  • 226
« Reply #2 on: December 08, 2011, 10:42:14 PM »
 Built my x90 over 4 years ago with one of their kits. Had to do a little fine tuning but overall is as good as you can get/buy.
« Reply #3 on: December 09, 2011, 06:19:40 AM »
^^^ What he said^^^  8) Due to the custom application on my rig (37's on a Kick), we had to tweak it a little, but it is a durable top notch product that I have enjoyed bashing the crap out of over the past couple of years....
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #4 on: December 16, 2011, 04:25:08 PM »
I have one too and I have to say it's an excellent foundation.  I have done quite a bit to mine too to get it just the way I want. Recently did new shocks all the way around. I rotated the rear pinion up and am in the process of putting in the SYE and CV drive shafts. To do this you have to put in all new shock mounts cut off the spring mounts top and bottom and  rerun the ebrake cables etc etc etc.. It's actually quite a bit of work to do this radioactively.. If you plan to run the SYE and CV drive shafts make sure you set up the rear axle this way first..  The only reason I am going to go to a CV drive shaft is to get ride of a drive line vibration that I have on the highway.. I tried just about everything to get ride of it and no luck.. It a coasting vibration.. Only happens when I am not accelerating or decelerating.
couple things l think should have been included.. PS box frame reinforcement. Bump stops. Taller springs.. I have one of the early kits and I think the front pan hard bar has been improved.. I ripped mine off the frame.
The way brent sells the kit is all down travel. I like to go fast and that doesn't really work well on bumps/rocks over about 2" So I am running 14" 250Lb coils in the front and 18" 125lb coils in the back to give me about 5" of uptravel..
The other thing I don't like about the kit is the sub frame that all the links mount to.. I wish this was more like the samurai version. and tucked up better. It lowers you center ground clearance considerably and there has been several obstacles that this has gotten in the way.
So plan your kit out and see if you can get it with out shocks and coils and source your own depending on how you want to set up your truck...
It takes your rig to a whole new level of capability..
