changing a transfer case 95 geo tracker
  • 4961 Views
« on: October 27, 2011, 07:30:00 AM »
Ok are automatic and manual transfer case the same?
and do you have to remove transmission and to change any help will of great use
Re: changing a transfer case 95 geo tracker
« Reply #1 on: October 28, 2011, 08:31:38 AM »
Yes, manual and auto tcases are the same.  You will need to replace it with a tcase from an 89-95 tcase though, because in 96 they changed the output shaft spline count.
It is easier to remove the tranny, in order to remove the tcase, IMO.  If you have a manual tranny, you have to take the tranny shifter tower off, because there is a hidden bolt underneath it, and the tcase won't come off, without it being removed.
