Tracker clutch cables
  • 2702 Views
Offline wapitijames
  • 30
« on: October 30, 2011, 02:49:16 AM »
Does anyone know if it matters whether you use a 62" housing cable or a 66" housing cable? They are both the same overall length, it's for a 94 Geo Tracker 5-spd with the 2 nut hanger at the transmission as opposed to the rubber mounting type, thanks.
Offline wapitijames
  • 30
Re: Tracker clutch cables
« Reply #2 on: October 31, 2011, 10:02:14 PM »
Thanks ranger88den, I was sold a 62", but it looks like I should have been given 66", could be my problem!!
« Reply #3 on: November 01, 2011, 05:26:07 AM »
No personal experience with the Tracker clutch - however - I've a fair bit with cable operated clutches on other vehicles.  I can't see the length of the casing as causing the problem - cable operated device rely on the difference in length between the inner and the outer - so I see that as an either work/not work situation.
On a different note - and this really relates more to your other post - I have had clutch cables cause problems like you describe, with the pressure required to operate the clutch gradually becoming heavier - it started with my daughter complaining about how heavy the clutch was and when I realised it was unusually heavy, I put a new clutch in, all genuine Suzuki parts, and the problem went away for about three days - lubing the cable (which I had not replaced) resolved it for awhile, and I would have relube the cable repeatedly, so I replaced it.
You may want to check the ground strap that runs from the bellhousing to the battery negative - if it's not there the starter grounds through the clutch cable and that can cause it to overheat and melt the platic lining on the casing.
Offline talonxracer
  • 1284
« Reply #4 on: November 02, 2011, 05:57:56 AM »
The issue I have encountered with these damn cable clutchs is the wide range of the engagement point when cold or hot and I am always having to get under the truck to adjust the cable at the trans end. The cable and clutch was brand spanking new when I purchased the Sidekick as the PO had clutch issues (that ended up being the weld on the clutch pedal cross shaft) I am sure the cable was a el-cheapo cable and does see a fair amount of stretching as well as a cheap clutch that does not have a thermally stable friction material.
Offline wapitijames
  • 30
« Reply #5 on: November 03, 2011, 07:42:58 AM »
I got a proper 66" cable, problem seems to be gone.........................for now!! Thanks for the input.
