Engine Knock Ping Pre Ignition
  • 2824 Views
« on: October 31, 2011, 10:58:55 AM »
Hi all,
I have a 94 sammy 1.3TBI 130,000mi and it's driving me crazy.  I have what sounds like preignition when I accelerate.
-Hot or cold does not matter
-RPM does not matter
This is what I have tried so far...
-Disabled the timing advance and retarted the timing
-thicker oil (maybe a engine knock)
-no engine codes are present
-MAP is okay  (if i disconnect it to open loop it still makes the noise)
-High octane gas.
What I might do next...
new spark plug wires
new cat converter (maybe causing the noise but it's a long shot)
engine rebuild (maybe carbon build up)
Re: Engine Knock Ping Pre Ignition
« Reply #1 on: November 03, 2011, 04:11:33 PM »
That sounds like a weird one.  Can you get the noise if the vehicle isn't under load, and your just revving it up from under the hood?
« Reply #2 on: November 10, 2011, 09:20:02 AM »
Once and a while I can get the noise when not under load but not all the time.  I thinking it's a rod bearing or something.
Offline SnoFalls
  • 1358
« Reply #3 on: November 10, 2011, 09:39:59 AM »
I'm thinking carbon buildup ...
Would be interesting to know compression numbers, and you could always try to seafoam it ...
Offline talonxracer
  • 1284
« Reply #4 on: November 10, 2011, 10:14:00 AM »
Have you taken the time to check the valve lash?
« Reply #5 on: November 10, 2011, 11:16:03 AM »
I have checked the valve lash it's good.  Carbon buildup is an option but I did seafoam it and it made no difference at all.  The compression is 150psi in all cylinders a little low but should still be okay.
What should I try next??
Offline SnoFalls
  • 1358
« Reply #6 on: November 10, 2011, 11:48:08 AM »
Are you sure it's a pre-ignition "ping" ...
My chevy 2500 had a rattle from a loose heat shield that would "ping" only under acceleration (motor torque would shift things just enough to "ping"). I only managed to find it when one day it was off-camber and would "ping" sitting at idle.
« Reply #7 on: December 21, 2011, 05:12:37 AM »
Found it!  It was a cracked piston.  I caught it in time so I'm able to rebuild.
« Reply #8 on: December 28, 2011, 06:59:27 PM »
Lucky.  :)
