Technical Discussion - Beginner / Repair
Speedometer cable removal
jga154
28
November 03, 2011, 06:48:32 PM »
86 Samurai; Can the speedometer cable be removed without draining the fluid first or will all the fluid leak out?
Thanks,
Jim
86 Samurai Tin top, OME Springs, Bonz shackles, 30x9.50, 4.9:1 TC, rear Lockright locker, Rocky Road Outfitters DIY front bumper
Skyhiranger
3734
122
I don't buy, what I can build
Re: Speedometer cable removal
November 04, 2011, 08:13:59 AM »
Yes, you can remove just the cable from the tcase and no fluid will leak out. Remove the bolt from the bottom part of the tcase speedo assembly, wiggle the cable and it should slide right out.
