88 ZUKI SAMMI
  • 2397 Views
88 ZUKI SAMMI
« on: November 09, 2011, 04:31:47 PM »
WHEN I CRANK IT , IT RUNS.  WHEN I GO TO DRIVE IT CUTS OUT LIKE IT ISNT GETTING ENOUGH FUEL.  I REPLACED THE FUEL FILTER.  WHAT ELSE SHOULD I CHECK?  AS SOON AS I GO TO DRIVE IT IT PUTTERS AND KILLS.  PLEASE HELP.
Re: 88 ZUKI SAMMI
« Reply #1 on: November 11, 2011, 08:07:39 AM »
I changed the fuel filter and fuel pump....nothing.  Come on guys and gals, need some help here.  Thanks
Re: 88 ZUKI SAMMI
« Reply #2 on: November 11, 2011, 09:59:22 AM »
Will it rev up without stalling, or only idle?
Re: 88 ZUKI SAMMI
« Reply #3 on: November 12, 2011, 03:29:22 PM »
Does it have the stock carb on it?  Might need a rebuild.
Offline ebattleon
Re: 88 ZUKI SAMMI
« Reply #4 on: November 14, 2011, 06:29:27 PM »
The jet on the secondary venturi may be clogged, or the carb could be flooding. However I lean more on the former.
You need to service the carb, if you do not have any idea how to find some body who knows!!!
Common Sense Absent
Re: 88 ZUKI SAMMI
« Reply #5 on: November 15, 2011, 10:53:48 AM »
Heck, might just need the Ventury tube...
Re: 88 ZUKI SAMMI
« Reply #6 on: November 15, 2011, 04:29:22 PM »
gosh I am so crazy...it was the spark plugs.  thanks for the help.
Re: 88 ZUKI SAMMI
« Reply #7 on: November 16, 2011, 01:10:35 PM »
I once took a car into a shop because I couldn't track down a mis-fire issue.  Ends up the plug wires were bad and I had forgotten to replace them.  :D
