Technical Discussion - Beginner / Repair
Check engine light
Check engine light
FWD
7
Check engine light
November 09, 2011, 08:42:05 PM »
My check engine light recently started coming on intermittently (now on for good). When on it runs very rich. The light flashes 4 times, twice. Is that a code I can look up somewhere? I've done my best to check all the vacuum hoses, dident find anything.
Any suggestions?
weldboy
91
2
I'm only here for the carnival atmosphere !!!
Re: Check engine light
November 09, 2011, 08:56:28 PM »
Here is Code 44 Idle switch of TPS, open circuit
That is your throttle position sensor
talonxracer
1284
34
November 10, 2011, 05:14:29 AM »
The ECU has entered limp home mode, it is literally dumping a bunch of raw fuel in to be safe. I would check the condition of the TPS's connector, reset the ECU and see if it comes back.
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #3 on:
November 10, 2011, 03:31:05 PM »
If the ECU detects a bad idle switch it uses a default setting of 0.5V. It shouldn't have too much effect, that exactly how all the later ECUs work (no idle switch on those). You should check that the TPS is correctly adjusted and that there are no bad spots on the TPS itself.
http://www.rhinopower.org
lv2fsh
312
19
Reply #4 on:
November 11, 2011, 08:06:09 PM »
What kind of car? Sammy or kick and what year/engine?
