Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998
noisy injector
noisy injector
moody
10
noisy injector
November 11, 2011, 06:25:16 PM »
I have an 89 tracker with TBI and the injector is pretty noisy. Does this mean it is going bad or do they typically make noise. I have noticed that newer trackers 90 and up don't seem to make as much noise. Should I be on the safe side and replace it? I'm not having any performance issues it seems to run good and I get good gas mileage.
talonxracer
1284
34
Re: noisy injector
November 12, 2011, 07:46:42 AM »
Fuel injectors do make a fair bit of noise and usually more as they get bigger. As long as the mileage is decent and she is running smoothly I wouldnt worry too much, but it wouldnt hurt to run some quality injector cleaner through the fuel system.
moody
10
Re: noisy injector
November 12, 2011, 08:42:12 PM »
Thanks! I'm going to run a test tomorrow and see if it's the injector or the ISC valve. I would much rather pay to have the injector cleaned than try to find a replacement ISC.
Drone637
8121
116
Evil Cow
Re: noisy injector
Reply #3 on:
November 15, 2011, 09:24:18 AM »
Whatever you do, don't hit it with 12v to see if it clicks. That trick only works on the multi-port injectors, with the TBI setup it will just burn out your injector.
