15 x 7 Aluminum wheels $200 + shpng
  • 16 Replies
  • 4958 Views
Offline mrdezyne
  • 181
« on: November 14, 2011, 08:19:41 AM »
Up for grabs, a set of 4 straight aluminum wheels with center caps and lugs.
$200 plus shipping
Open to trades of cool bits and pieces, whatcha got?
Interior panels, aluminum or plastic
rear corner aluminum tread caps
front or rear bumpers?
« Last Edit: November 14, 2011, 08:22:22 AM by mrdezyne »
Re: 15 x 7 Aluminum wheels $200 + shpng
« Reply #1 on: November 16, 2011, 06:30:40 PM »
location
Offline canadiantbone
Offline mrdezyne
  • 181
« Reply #3 on: November 17, 2011, 07:45:10 AM »
These are in Tulsa OK, Broken Arrow actually, zip 74014
I've scrubbed them front and back and they don't look too bad.  A little elbow grease and they will probably polish up really nice.  Center caps and lugs are chrome and all accounted for.
They were fitted with 33x 12.50 when I bought the zuk, I've since replaced with 15x8's and different offset.
Let me know if we can work something out, they are taking up 2.8619 cu ft of valuable space in my garage... :)
Offline mrdezyne
  • 181
« Reply #4 on: November 18, 2011, 11:49:34 AM »
Weekend bump to that top...
these would ship cheap via Grayhound bus lines.  If you have a depot close buy I can ship them there for you to pick up.  Anyone need a winter set of wheels? or?....
« Reply #5 on: August 12, 2012, 10:20:30 PM »
Hey n e chance you still have these wheels for sale?
Offline mrdezyne
  • 181
« Reply #6 on: August 21, 2012, 08:30:56 AM »
Hey Grayman, yes I still have the wheels, they are just sitting in storage.  Sorry I didn't get a notice you had responded to this post and I just happend to see your question.
Offline Jonny Rash
  • 1094
  • 21
« Reply #7 on: August 21, 2012, 09:00:10 AM »
Hey, I might be interested in them and I am located in Tulsa as well.  Might be good just to link up and talk Zuks.
Offline mrdezyne
  • 181
« Reply #8 on: August 21, 2012, 03:17:36 PM »
Hey Johny, when things slow down at work and I have a chance to get back on the build I'll give you a call and have you come over to check it out.
On the wheels, I'll give Grayman a chance to respond first but if he decides he doesn' want them you have second dibs.
« Reply #9 on: August 23, 2012, 10:41:51 PM »
Hi MRDEZYNE,
Thanks for the offer to give me first crack at the wheels.  I am interested in them.  I have used greyhound before and it works pretty good.
I have a couple of questions as I am new to the zuki world.  I am wondering if the wheels that were on your ZUKI cleared with the lift you have, with the 33 12.50s and did you run them with or without a spacer?  Some people seem to run spacers?
I am planning on first running 30 inch tires and then if I go bigger later I could run the bigger tires on the same wheels?  so initially, I should have no problem with 30's on those wheels.
Again I am pretty sure I want to get them from you right away, thanks for honoring the first come,,,,basis,,
GRAYMAN SPOTTER
Offline mrdezyne
  • 181
« Reply #10 on: August 27, 2012, 07:11:19 AM »
Hey,
The tire wheel combo that came on the rig when I bought it was these 7" wide wheels with 33x12.50 tires and they did rub on the leafs before full turn.  That is one reason I got something with a little less backspace and stayed with the large tire size.  You might be fine with 30" tires depending on the width you go with.  Spacers would certainly be a good safety factor to consider.  I'll double check the backspace of these wheels this week.  But I think with a smaller tire they would be ok.
Personally I don't think 7" is wide enough for a 12.5 tire, stick with a 10.5 width or smaller for these wheels.
« Reply #11 on: August 27, 2012, 04:09:40 PM »
Thanks for the info, and I found you are right on the tire size.  backspacing info will be great.
Hsve you thought much more about how to get this transaction done? How you can "wrap them up" to travel on Greyhound?  I figure I will just send you the doe and after you cash the check you can ship them out. let me know, of course i will have to pay you for shipping too cuz if I remember right you have to pay when you drop them off.
Offline mrdezyne
  • 181
« Reply #12 on: August 28, 2012, 07:32:19 AM »
PayPal is always quick and easy.  I can get them packaged up easy, I've shipped everything from BMW seats, exhaust systems, to other wheel and tire combo's.  I'll double check what shipping would be from my freight dock here at work.
« Reply #13 on: August 29, 2012, 08:51:24 PM »
Thanks
Did you get a chance to check how much backspacing they have?
Its my guess that greyhound will be the cheapest, wieght will be the issue outside of Greyhound.
Offline mrdezyne
  • 181
« Reply #14 on: August 30, 2012, 02:30:32 PM »
hey Gray,
I did find this from my Craigslist ad:
A set of four American Racing Outlaw wheels.
2 piece aluminum lightweight wheels, solid face, all four straight and true, need refinished for best appearance. 3.75" back spacing, 5x5.5 bolt pattern
