87 Samurai shuts off after big bumps and speed bumps.
  • 3681 Views
Offline ajwilson46
  • 22
« on: November 15, 2011, 12:48:07 PM »
Ill hit a speed bump or a bump in the road and it will shut off. I have to let it sit for a few minutes then hammer the throtthle to get er' going. Electrical?...Fuel problem?..or what??
87 Samurai JX Hardtop
87 Jx Soft top
86 JX Soft top
Offline ebattleon
Re: 87 Samurai shuts off after big bumps and speed bumps.
« Reply #1 on: November 15, 2011, 06:43:54 PM »
Type of carb?
If it is a carb its flooding, probably the check valve leaking or the float has failed.
Common Sense Absent
Offline ajwilson46
  • 22
« Reply #2 on: November 16, 2011, 10:59:39 AM »
Stock Carb
87 Jx Soft top
86 JX Soft top
Offline Capt
  • 738
  • 28
« Reply #3 on: November 16, 2011, 04:43:22 PM »
Time to get a replacement carb.
The "Fuel Shut Off & Metering Valve" is heading south!!
This is the "Electric" plunger that is in the fuel bowl that meets the O-ring in the well floor.
Sorry this is "Not a Service-able Part" ...................
When mine took a $~!t, I replaced it with a Weber Carb.
CAPT
Offline ajwilson46
  • 22
« Reply #4 on: November 21, 2011, 09:25:34 AM »
How much would i have to throw down for a decent webber or eddlebrock?
87 Jx Soft top
86 JX Soft top
Offline Capt
  • 738
  • 28
« Reply #5 on: November 21, 2011, 04:22:28 PM »
Check with LowrangeOffRoad,  one of the vendors on this site.
They will have all the INTELL on what you need...... for what you want your rig to do.
Mine was a complete replacement kit, ready to bolt on, $425.00 including freight about 2 years ago.
CAPT
Offline ebattleon
« Reply #6 on: November 23, 2011, 05:35:07 PM »
You can also consider this rebuild carb from here
http://www.nationalcarburetors.com/cat-toyotacar.html
COROLLA 3KC 1166 CC ENGINE
I have one of these installed an it is the closest to stock carb that i ever had in terms of fuel economy. And it straight bolt in, but you will need to change to acc cable cam off it and use the samurai one instead. Every thing else is the same. You could also check these same guys to see if they can rebuild your carb for you.
« Last Edit: November 23, 2011, 05:43:35 PM by ebattleon »
Common Sense Absent
« Reply #7 on: November 23, 2011, 10:54:59 PM »
check the little green plug off the battery.mine would shut down. changed plug both ends.
88 Sammy coils front,rear. 8:1 tcase,5:12,and 37-12.5-16.5 on double beadlocks. arb front spooled back.
96 X90
00 Vitara
