94 4 door front spline count
  • 10 Replies
  • 2893 Views
Offline 1bigtracker
  • 3409
« on: May 09, 2004, 01:17:13 PM »
i have just bought a 94 4 door kicker with the 5 speed with the "big block" 1.6.  i am wandering of it has 22 ir 26 splines in the front end?  and are all the CV outer(part that goes into the hub) the same from 22 spline to 26 spine?  thanks
stu
Offline Speedracer7c
  • 2210
Re: 94 4 door front spline count
« Reply #1 on: May 09, 2004, 01:19:27 PM »
I call rear diff!!
Offline 1bigtracker
  • 3409
« Reply #2 on: May 09, 2004, 01:20:58 PM »
saw that one coming. ::)  poor deprived(sp) zooker.
stu
  • 2210
« Reply #3 on: May 09, 2004, 01:25:01 PM »
I know!! I've gotten hosed on the rear end I paid for, and my body lift still hasn't come!
« Reply #4 on: May 09, 2004, 01:34:17 PM »
22 spline, the outer shafts are the same
Offline 1bigtracker
  • 3409
« Reply #5 on: May 09, 2004, 01:40:03 PM »
sweetness.  don't need to change everything now.
stu
Offline explosivo
  • 3157
« Reply #6 on: May 09, 2004, 01:55:36 PM »
Is all this 22 and 26 spline talk referring to the outer part of the CV shaft that goes into the hub? If so, what years had 26 spline, and are they a worthwhile upgrade?
omghi2.us[/url]
« Reply #7 on: May 09, 2004, 06:14:20 PM »
No, it's the axle splines that engage the
side gears in the diff.
The outer driveline is the same,
26 splines engage the lockout hubs.
Crabzuki
« Reply #8 on: May 10, 2004, 12:12:58 AM »
Speedracer7c, if I were you which I'm not, I would give Calmini a call to see if there is something wrong with the billing or shipping. You may be lost in the paper work. I got my body lift today (05/10/04) and I live in Maryland.  ;D  ;D  ;D
Offline 1bigtracker
  • 3409
« Reply #9 on: May 10, 2004, 08:22:21 AM »
so all hubs are 26 spline?
stu
Offline explosivo
  • 3157
« Reply #10 on: May 10, 2004, 08:40:14 AM »
Do people have problems with 22 spline shafts with large tires (33's)? To do this upgrade, which parts would I have to change out?
omghi2.us[/url]
