Manual trans rebuild with synchros question
  • 2030 Views
Offline mrdezyne
  • 181
« on: November 21, 2011, 12:36:20 PM »
Hey, I pulled my onld 1.3 with trans this weekend to make room for my fresh and new 1.6 8v.  Since the trans is out I was going to rebuild it, just one of those "might as well do it while its out" kind of things.  I bought the kit with synchros but the rebuld threads that I have found only have info on replacing the bearings.  I haven't torn into the case yet so the answer might be obvious once I'm in there but,  is changing out the synchros a trick or are there any special tools needed beyond the tools needed to replace the bearings?
Any pics would help, thanks.
Re: Manual trans rebuild with synchros question
« Reply #1 on: November 21, 2011, 06:20:13 PM »
 Pretty much the same.  I did one a year ago.  My best advise is to get yourself a nice long workbench and put some towels on it and lay out the parts in order of removal.  I've been an auto tech since 1990 and I even lost my place for a couple minutes with the mainshaft disassembly.   I put bearings in a Tracker tranny about 2 years ago and didn't do the synchros....big mistake.
Offline mrdezyne
  • 181
« Reply #2 on: November 22, 2011, 06:59:43 AM »
Thanks, thats what I needed to hear.
So there is nothing special about the synchros in the stack up, just replace as they come off the shaft in the same order and orientation and I should be ok.  I'm sure it will become more obvious once I crack into it and see what I'm working on.
Thanks agian.
Offline ebattleon
« Reply #3 on: November 22, 2011, 10:53:47 AM »
Suzuki Field Service Manual.... ::)
http://www2.izook.com/?page_id=435
Color pics and step by step rebuild process
« Last Edit: November 22, 2011, 10:59:55 AM by ebattleon »
Common Sense Absent
Offline mrdezyne
  • 181
« Reply #4 on: November 22, 2011, 11:59:12 AM »
Been there, seen that, only a bearing swap.  No synchros...  Thats the link i was refering to in the first post....  :(
