Carb Removal Tips
  • 1596 Views
Offline Breeze-O-Top
  • 89
    • Breeze-O-Top Safari and Bikini Tops.
Carb Removal Tips
« on: November 21, 2011, 05:18:16 PM »
It looks like I need to remove and replace my stock carb on my 87 Sami. I narrowed down my poor running to the carb. Petroworks has them for about $585 for a rebuilt unit. Is that on the high side? I trust them to do a good job. I met the rebuilder and he seems to know what he is doing.
Second issue, is there a link on getting the bowl of spaghetti of hoses off in order (tips), and I can only see two of the nuts for removal.
Any advice on the carb removal?   ???
Owner of breeze-o-top.com
Stock motor, K&N air filter, MSD Blaster Coil, 30" tires.
4:16 gears with front and rear Lockright Lockers. Old Man Emu springs and a mild lift. Custom angle iron bumper, army ammo can storage. Petroworks dual friction clutch. CB & 2 meter ham radio. And other fun things!
Offline weldboy
  • 91
  • I'm only here for the carnival atmosphere !!!
Re: Carb Removal Tips
« Reply #1 on: November 21, 2011, 08:15:58 PM »
You have 2 nuts on the battery side which you probably see, and the other 2 are toward the valve cover side under the vacuum hoses. I cut the open end part of the 12mm wrench to make it shorter and easier access to turn the nuts. For vacuum hoses you should have a diagrahm on the underside of the hood or you can find it at Ack's faq website. It really looks alot worse than it is. Hope this helps. ;D
  • 89
« Reply #2 on: November 23, 2011, 01:59:10 PM »
I found the location of the four nuts, I had to move the hoses around to spot them. Still looking for a good link to remove the carb.
