vitara with baleno
  • 2179 Views
Offline y.z
vitara with baleno
« on: November 26, 2011, 12:55:08 PM »
I wanted to know if the distributor Vitra 93 of carburetor, Appropriate  to engine baleno 97.
I want to fit this baleno engine for my vitara but have a problem with the distributor
Thank you
Re: vitara with baleno
« Reply #1 on: November 26, 2011, 03:51:40 PM »
Does your Baleno have a distributor? if it doesn't then you would need to change the camshaft.
Offline y.z
« Reply #2 on: November 26, 2011, 11:14:36 PM »
Yes it baleno engine with the model of distrbotor.
So the distrebotor of the V8 will fit the Cylinder head of 16V?
« Reply #3 on: November 30, 2011, 03:08:28 PM »
Possibly not, the 8V distributor rotates in the opposite direction so if you have a distributor from a carb model with mechanical and vacuum advance then it won't work.
If its an electronic distributor then you should check the number of teeth on the sensor wheel because some balenos and Esteem had 5 teeth with the 5th tooth synchronising the ECU to number one TDC.
My Baleno is distributorless so I'm afraid that I can't be more specific.
