Spoa lift w/stock springs vs yj kit
  • 2109 Views
« on: November 28, 2011, 08:57:57 PM »
So my 87 samurai has a spring under lift kit with the leaf spring and shackles with 31inch tires. All my friends have spoa lifts with stock springs and stock shocks. I am wanting to up grade my lift but not sure what is better  stock springs or yj springs. Once that is figured out what do I have to do to the steering to make it right I already have the longer pitman arm?
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Spoa lift w/stock springs vs yj kit
« Reply #1 on: November 29, 2011, 01:10:19 PM »
If you want the lift and additional flex go with the YJ's. For the steering you should go to 1/2 or full high steer for the best set up available.
Offline ebattleon
« Reply #2 on: December 01, 2011, 04:58:13 PM »
Planning to go over 31's then YJ...
Common Sense Absent
