HOME MADE SNORKEL
  • 10 Replies
  • 8358 Views
Offline ColtonP
  • 147
HOME MADE SNORKEL
« on: December 08, 2011, 04:58:56 PM »
Looking to see if ne one has put a home made snorkel on a 95 style kick. And want to know the effectiveness . How you did what tools and parts needed. THANKS
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Offline PierPaul
  • 100
Re: HOME MADE SNORKEL
« Reply #1 on: December 08, 2011, 05:51:56 PM »
Yes i'm also intersted to see some snorckel ,but maybe more complex than some abs pipe and a k&n on the top
Offline zuki1018
  • 397
« Reply #2 on: December 14, 2011, 10:37:21 AM »
Eventually I would like to come up with one that will allow for a fold down windshield.  Haven't really gotten close enough with the rig to figure that one out tho.
I wonder... if you fill PVC/ABS with play sand/water slurry and heat it up with a torch... could you get nice smooth bends out of it?  I bet it would still wrinkle the inside of the angles.  I can get pretty close to perfect on my 12 ton tubing bender like this with DOM tube. I just dont have large enough sizes for what an intake pipe would need.
Offline Boxcar
  • 936
« Reply #3 on: December 17, 2011, 07:08:32 AM »
Use a heat gun NOT A TORCH.....The syuff likes to burn...Boxcar...
God Bless
Offline talonxracer
  • 1284
« Reply #4 on: December 17, 2011, 05:39:01 PM »
You can use sand inside thin wall aluminum pipe(type used by the import tuners for cold air intakes) to maintain the profile for a fairly tight turn.
« Reply #5 on: December 21, 2011, 06:54:31 AM »
I just recently did a snorkel kit on my 95 Tracker.
I went to a salvage yard and got about 3 cold air intake kits off of Import cars, I cut and linked them all together.
I am in the final stages of mounting it all up, and painting it.
I could post some pictures if you would like.
Offline mrdezyne
  • 181
« Reply #6 on: January 09, 2012, 02:24:15 PM »
there are places like this where you can buy all the tubing and connectors you need to fab one up...
http://www.siliconeintakes.com/
Offline talonxracer
  • 1284
« Reply #7 on: January 10, 2012, 06:16:57 AM »
A better plastic would be the grey electrical conduit. I have used heat guns and my pipe bender to get some very nice smooth bends for electrical conduit that is visible and goes around corners etc(cheaper than buying pre curved pieces and splicing them)
Offline zuki1018
  • 397
« Reply #8 on: January 10, 2012, 06:28:23 AM »
Good idea!  I will def. be staying away from having 15 couplings/splices.
Offline TinTopTom
  • 27
« Reply #9 on: January 17, 2012, 01:53:22 PM »
I recently saw a pretty good one that a guy made, wish I would have taken a picture so I could post it up...
It was made entirely of gray PCV electrical conduit, big stuff. He used a 90deg 'pull box' to make the penetration into the bodywork at the fender, it was pretty low-buck and inventive.
Building stuff is a way of life
Offline yellow2000S/R
  • 152
« Reply #10 on: January 30, 2012, 03:07:43 AM »
Late reply, anyhow 2" is restrictive as I noticed on a few local hills. Want to redo it but in 2.5" or 3" steel probably so I can weld it.
