Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998
trouble shooting engine misfire, 96 x-90
sumozuki
22
I Love ZUKIWORLD!
December 20, 2011, 10:31:12 PM »
1.6 16 v 96 x-90 auto, engine runs fine until I put the auto transmission in drive then it develops a misfire.
talonxracer
1284
34
Re: trouble shooting engine misfire, 96 x-90
December 21, 2011, 06:48:47 AM »
Have you changed plugs and wires? Any CEL codes? EGR system may need to be checked,cleaned.
sumozuki
22
I Love ZUKIWORLD!
December 23, 2011, 11:06:56 AM »
Thanks talon, i pulled up a iat code & fixed that, plugs, cap & wires were done also,will chk the egr now, i hope thats it,i'll let ya know!
Drone637
8121
116
Evil Cow
Reply #3 on:
December 24, 2011, 12:58:36 AM »
I would also check the 02 sensor. Sometimes a bad 02 can cause some weirdness.
talonxracer
1284
34
Reply #4 on:
December 24, 2011, 08:56:36 AM »
Also a cracked exhaust mani(usually between #3 and #4) can cause a over rich condition resulting in misfires.
sumozuki
22
I Love ZUKIWORLD!
Reply #5 on:
December 30, 2011, 07:05:47 PM »
swap egr, no change
KJMac
280
3
Reply #6 on:
December 31, 2011, 01:20:30 AM »
Quote from: sumozuki on December 30, 2011, 07:05:47 PM
swap egr, no change
Did you swap out the module...diaphram? That was the problem with mine!
Last Edit: December 31, 2011, 01:42:45 AM by KJMac
BRD HNTR
2300
56
Reply #7 on:
December 31, 2011, 08:54:07 AM »
Misfire as in firing at wrong time, or not firing when required? If is
not
firing properly when shifting into drive, leave in drive and pull plug wires one at a time to find bad cylinder. Move injectors and retest to see if problem moved.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
sumozuki
22
I Love ZUKIWORLD!
Reply #8 on:
January 03, 2012, 07:57:10 PM »
Got er goin, THANK YOU EVERYONE 4Ur Input, KJMac you were right in the $$, Diaphram did fix it!
