i want a lower gear reduction NEED HELP! im new
  • 14 Replies
  • 4985 Views
« on: December 24, 2011, 11:58:31 PM »
i want about a 6:8:1 gear reduction so she will creep and crawl please all info will be very thankfull!! show me how much you know!!!!!!!
Re: i want a lower gear reduction NEED HELP! im new
« Reply #1 on: December 25, 2011, 05:02:39 AM »
In what?  ???
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: December 25, 2011, 07:37:48 AM »
akapeewee:
Alas, we are not psychics.
Your post does not tell us exactly (or even generally) what Suzuki vehicle that you have.
Your post only tells us of your goal in very broad terms - you want to crawl using "about" 6.8-1 gears.
The first thing you need to do is read and learn more about whatever Suzuki 4x4 truck that you own, then start asking questions here to fill in the gaps.
Knowledge is the best tool to use to reach your goal.
I would suggest visiting Ack's FAQ (http://www.acksafaq.com). There is an easily-searchable database of over 800 links to helpful information on the internet - much of it found right here at Zukikrawlers.com!
Ack's FAQ also has two useful gearing calculators (one designed specifically for the Samurai) that can help you create the gearing/tire setup most suited for your vehicle.
I hope that this helps!
Ack
« Reply #3 on: December 25, 2011, 11:30:52 AM »
i have a suzuki samauri year model 87/88 i think for parts since it was made in a late month, what kind of transfer case does it have? i believe it has 5:11 gears in it now
« Last Edit: December 25, 2011, 11:34:09 AM by akapeewee »
Offline my996duc1
  • 222
« Reply #4 on: December 25, 2011, 11:52:55 AM »
6.5 gears or 6.4 gears are about 6.8.
maybe some more info about if you are making a strickly creep and crawl rig or is it also going to need to run down the road.
maybe some more info on other mods done too.
Alot of info and a great wealth of knowledge on the forum here.... just need more specific questions and giving the members more info will only help you out.
_
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #5 on: December 25, 2011, 03:15:57 PM »
What size tires are you trying to run?  Does it currently have a lift on it?  What size tire does it currently have?  Once we have some more info we can start tossing suggestions your way.  :)
« Reply #6 on: December 25, 2011, 10:36:05 PM »
prolly like a 2 inch light suspension lift  ]] biggest tires will be 33 12x50s
its the 1.8l it needs a little help i think
32'' gumbo mudders
« Reply #7 on: December 27, 2011, 10:37:41 PM »
my 88 sam had now 8:1 tcase gears and 5.12 front and rear. and iam pushing 37 12.5 on double beadlocks. and every things o out on my odometer. all stock again. getting 19.998 mpg thats so cool.
88 Sammy coils front,rear. 8:1 tcase,5:12,and 37-12.5-16.5 on double beadlocks. arb front spooled back.
96 X90
00 Vitara
« Reply #8 on: January 01, 2012, 07:27:55 PM »
what kind of tcase is in yours?
« Reply #9 on: January 05, 2012, 06:42:31 PM »
He is using a stock Samurai Transfercase with an 8:1 gear set.  The high range is the same as the 6.5:1 kit, so you can go with either one.
For 33" tires with stock axles I would recommend the 6.5:1.  But fitting them with only 2" of lift is going to be a bit of a chore.
Offline Kazang8272
  • 9
« Reply #10 on: January 06, 2012, 01:22:57 PM »
Yeah a lot of hacking to get 33 s under there with only 2 in of lift, n where can u source 8.1 gear reduc kits now didn't think they were avail anymore n how well does your case hold up to them
1988 Samurai spoa, 1.5 in spring lift, sidekick thrids, 4.16 trans reduc, 33 in procomps
1990 Samurai pretty stock still
2003 Toyota Tacoma 6 in pro comp lift, 35 in bone crushers, 5.10 thirds, dc 2 wheels
« Reply #11 on: January 06, 2012, 09:42:59 PM »
I am pretty sure you can't buy new 8:1s anymore.  And I rarely see any used sets for sale.
Your best bet is to go with 6.5s in the tcase and regear the axles too (which is the proper way to do it anyway).  There are several options for regearing the axles.....using gears from a tracker/sidekick you can regear the stock samurai axles (3.73 gears) to 4.30, 4.62, 4.88, 5.12, 5.38, 5.62.  I also believe you can get 4.57 and 5.38 gears through the aftermarket.  It also seems like there is another ratio that is available through the aftermarket, but I can't remember what it is.
« Last Edit: January 24, 2012, 06:09:16 PM by Skyhiranger »
Offline rockrat
  • 196
  • Got Ringr
« Reply #12 on: January 24, 2012, 05:59:38 PM »
In an aftermarket gear all that is avail. is 4:57 5:38... The 5:83 we cant get anymore
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #13 on: January 29, 2012, 12:11:50 PM »
Are you running Yota or Zuk axles?
« Reply #14 on: January 29, 2012, 08:55:54 PM »
He is running Zuki. :)
