Interchange ?
  • 3993 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Interchange ?
« on: December 31, 2011, 08:21:19 AM »
Does anyone know if the exhaust side of the head is the same pattern on a G13, M13A, M15A compared to an 8v or 16v head? The reason I ask is I found some turbo manifolds online for the "G and M" series motors and am wondering if they would match to the 8v or 16v head?
Thanks
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Re: Interchange ?
« Reply #1 on: January 01, 2012, 01:39:29 PM »
A G13A or G13BA exhaust manifold will bolt up to a G16B 8V engine. A G13BB exhaust manifold will fit a G16A or G16B 16V head. I don't think that the M manifold will fit any G series - the Jimny or Swift guys would know that.
You would have to check clearances, the turbo manifolds are usually designed for a front wheel drive application.
Offline biker
  • 730
Re: Interchange ?
« Reply #2 on: January 01, 2012, 04:16:04 PM »
Thanks for the info Rhinoman :) I thought this one looked like it might fit my 16v and it points the turbo out away from the block. http://www.ebay.ca/itm/Turbo-Exhaust-Manifold-SUZUKI-Solio-Swift-G13-T25-Flang-/290646134364?pt=AU_Car_Parts_Accessories&hash=item43abdc0e5c
« Last Edit: January 01, 2012, 04:17:42 PM by biker »
99 Vitara 2wd
10 Gr Vitara
Re: Interchange ?
« Reply #3 on: January 11, 2012, 04:01:08 AM »
That would be great if it fits the manifold, but you may have fender well clearance issues with the turbo mounted that way.
Offline biker
  • 730
Re: Interchange ?
« Reply #4 on: January 15, 2012, 05:45:35 PM »
How much space does the turbo take up, I'll check clearances when the manifold gets here, I hope this week.
99 Vitara 2wd
10 Gr Vitara
