Need help---gas pump
  • 1471 Views
Offline Duleau
  • 17
  • Hunting not a passion it's an obsession
« on: January 01, 2012, 05:55:33 PM »
I have a old 1989 tracker that i use to snow plow the yard with.
The wires to the gas pump are all rotten and i was wondering if i could plug it direct to the battery with just a little rocker switch in the cabin?
Can the ground be plugged direct to the frame or do i need it to come from the battery to?
Thanks
2000 Chev tracker 4 Door,2 liter,5 speed Stock for now
91 tracker Pickup  2 inch exaust with turbo muffler Cone filter 31 Mt Tecno Explorer Remoulds Welded rear 3 inch body lift 1 1/4 front spacers,2 inch rear spacers 1 1/4 inch strut spacer 91 crown vic rear shocks
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Need help---gas pump
« Reply #1 on: January 02, 2012, 02:41:48 AM »
Yep, you could do this and the ground can go directly to the frame. But then your hot wire could be taken from the ignition fused side of the electrical switch which would eliminate the need for an accessory switch.  ;)
