dodge neon stx seats
  • 20 Replies
  • 7382 Views
Offline MY-UKI-RIDER
  • 49
  • DRIVE SAFE.....BUT RIDE'UM HARD!!!!!
« on: January 03, 2012, 10:29:22 PM »
2001 Dodge neon STX, Does it bolt on? if so post some picture. Found a guy selling it for $50 buck.
Re: dodge neon stx seats
« Reply #1 on: January 04, 2012, 03:44:48 PM »
I assume you are asking if they bolt into a Samurai.  They will bolt in but you will have to drill new holes in the seat bracket.  I also had to do some grinding to get them in perfect.
  • 49
« Reply #2 on: January 04, 2012, 05:20:54 PM »
Any pictures are welcome
« Reply #3 on: January 04, 2012, 07:29:21 PM »
No close ups on the install but here is the finished product:
« Last Edit: January 04, 2012, 07:32:25 PM by Ag_xterra »
  • 49
« Reply #4 on: January 04, 2012, 09:30:30 PM »
WOW! Now thats one Bad ASS samurai..... Makes me wanna paint my ride soon
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #5 on: January 05, 2012, 01:39:10 PM »
There are no direct bolt in seats except Samurai seats. These look very nice as well as the Samurai they are in!!!
Offline Jonny Rash
  • 1094
  • 21
« Reply #6 on: January 05, 2012, 02:52:52 PM »
Are those Kayline doors or modified CJ7 doors?
« Reply #7 on: January 05, 2012, 04:00:44 PM »
Kayline
Offline Cheeto
  • 55
« Reply #8 on: January 06, 2012, 08:49:08 PM »
  • 49
« Reply #9 on: January 13, 2012, 08:51:39 PM »
Ok... I pick up the seats from the guy for... Even cheaper then what he was asking for $3 for both front seat Alright! My other question do I use the samurai track or can I use the neon track? The only bad is it doesn't fold forward. But its all good....
« Reply #10 on: January 13, 2012, 09:05:36 PM »
I used the samurai seat brackets and drilled them out.  The width of the mounting locations are within half an inch if I remember correctly but I did this mod around 7 years ago.  Its not a direct bolt in but pretty close if I remember correctly.  I didn't weld or fabricate a thing to make them work.  Goodluck.
  • 49
« Reply #11 on: January 13, 2012, 11:08:34 PM »
Thanks for the advice.... Can't waite to put them on... I'll post it when I done. I wanna try use the neon seat track even if I have to weld it.
Offline Capt
  • 738
  • 28
« Reply #12 on: January 14, 2012, 07:35:03 AM »
I did the same seat swap you have (From a 4 door, they won't tip forward)
I was able to use the stock Neon sliders on the passengers side. It will give you more leg room.I made brackets out of 2x2 by 1/8" angle iron for the front, and a piece of 1" square tube for the back. Line the 2x2 up with the factory seat support for the drivers side. Bolt to floor, then drill holes for Neon front slider brackets into vertical of 2x2. The back, just line up rear sliders on
1" sq. tube and drill bolt holes. (I climbed in thru back to drill these) Now wait before putting back bolts in as you will need 3-4 fender washers so both seats are matching each others back angle (Height).
For the drivers side, Drone637 posted a Very Good DIY on the bracket mod, maybe he can do it again for you as I could not
find it looking thru past posts. There is a little variant for the 4 door brackets, "CUT TOO SIZE....TRIM TO FIT !!"
I had to grind off a side brkt, and the rear spot welds, I rewelded mine but the drill & bolt will work. It is best if you take the seat apart so grinding & welding won't mess up your cloth covering. I thought I took some pix at the time but can't seem to find them either. They are probably still on a SD card, (those things are the size of a postage stamp...so easy to loose!!)
& I didn't keep them in my laptops Pix files.
CAPT
Offline vuzuki
  • 88
« Reply #13 on: January 14, 2012, 09:45:46 PM »
I just have to post to Ag_xterra, I'm eh.. afraid you are in the possession of stolen property.. I'm Not saying You stole it or anything.. but I'd really like tha-my samurai.. back now
  • 49
« Reply #14 on: January 15, 2012, 08:30:10 PM »
After 2.5 hrs. Of grinding, drilling with sweats. I'm loving it more. I end up using the samurai tracks.. here's some picture
