88 Sammi parts (Updated)
  • 2386 Views
Offline Tez
  • 11
« on: January 06, 2012, 11:22:29 AM »
Drum for drum brake
Passenger side door window
stock steering wheel with horn cover
Whole dash will part out cluster etc
Windshield washer reservoir and hose
Hard top back side windows
I have both rear seat belts male and female ends
Front 4x4 axle and rear axle
Sand blasted frame
Stock back seat
Front axle drive shaft
Steering box
Stock springs
sand blasted motor
stock headlights with bezels
blasted and polished head and intake and exhaust manifolds
3 purple fender flares
3 white fender flares
4 grey fender flares
Make an offer on what ever your interested in
my zip code is 5315 so please consider shipping
my phone is 262-215-4070 feel free to call/text about parts
I will ship same day time permitting
I have a lot more parts I will be putting up within the next week so keep an eye on the thread thanks!
Heres a link to pics!
http://s299.photobucket.com/albums/mm295/tezbaxter/Sammi/?action=view&current=DSC06227.jpg
« Last Edit: January 15, 2012, 10:20:16 AM by Tez »
Offline doubleoh7
  • 16
Re: 88 Sammi parts
« Reply #1 on: January 06, 2012, 06:03:54 PM »
do you have a set of stock front bumpstops??
1987 Samurai TT on 32x11.50x15's with 15x5.5 rims with Spidertrax 1" spacers.  4.89:1 T-Case Custom Rollcage and more to come...
Offline Tez
  • 11
Re: 88 Sammi parts
« Reply #2 on: January 06, 2012, 09:40:35 PM »
I don't right now but I should by Tuesday. I will pm you if I come across some
Offline doubleoh7
  • 16
Re: 88 Sammi parts
« Reply #3 on: January 06, 2012, 10:04:11 PM »
thanks for your help
Offline Tez
  • 11
Re: 88 Sammi parts (Updated)
« Reply #4 on: January 11, 2012, 11:17:37 AM »
Just put more parts up. Will have pics of the motor, axles and frame by the end of the day
Offline Capt
  • 738
  • 28
« Reply #5 on: January 13, 2012, 09:07:34 AM »
I see you have a Wisconsin area code.
Pick up/drop off/delivery should be simple......
Is the front drive shaft for the Small Diff Pinion Flange?
I'll check out the photo site you listed for more "Back Up Parts"
CAPT
Offline Tez
  • 11
« Reply #6 on: January 14, 2012, 10:13:05 AM »
Yes sorry For some reason the pictures of the frame axles and motor did not update to my photobucket. I will update them now and put them up so check them out!
Offline Capt
  • 738
  • 28
« Reply #7 on: January 17, 2012, 06:04:19 AM »
I was interested in the "Front Drive Shaft".
Mine is a 87 Sammy, the small pinion flange.
I want an extra drive shaft, I already have the other 2 for back ups while on the trail.
The Sammy shafts are so short, I carry "PreLoaded" spares, skip pounding out/in U-Joints,
It's just as quick to swap the whole shaft.
CAPT
Offline Tez
  • 11
« Reply #8 on: January 17, 2012, 11:20:09 AM »
I would imagine it would be almost as simple if not easier to just switch out the drive shaft. I still have it if your interested pm me
