Weld spatter on weld nuts
  • 13 Replies
  • 4655 Views
Offline the_maplebar
  • 466
« on: May 18, 2005, 05:42:44 AM »
I am installing a hitch on my tracker that bolts into the weld nuts in the frame and I ran into a problem.  3 of the weld nuts have som weld spatter on the threads  :-/.  I was able to clean the weld spatter off of 2 of the nuts using a punch and a hammer to knock it loose, but the 3rd nut has a fairly large bead that I can't get rid of.  To make it worse, the bead is right at the start of the threads so I can't even get a bolt started to try and force it  :'(.
Is there a better too or tacticl I should try to fix this problem?    Thanks for your help.
Offline Cwkick
  • 888
Re: Weld spatter on weld nuts
« Reply #1 on: May 18, 2005, 07:03:24 AM »
Use a tap!?!
Cwkick
  • 466
« Reply #2 on: May 18, 2005, 07:10:24 AM »
Thanks for the suggestion.  So I would be looking for something like this
[link]http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=39391[/link]
Now I just have to figure out how to use it.
Offline takai
  • 907
« Reply #3 on: May 18, 2005, 07:28:33 AM »
Taps are easy. Two simple rules. 1) Make sure it goes in straight. Cross threading and off-angle holes are miserable. 2) If you are having a really rough time use a cutting lubricant. It makes things a lot easier.  ;)
'Cause, I am to misbehave.
Offline N4TRBL
  • 63
  • <<ULTRA HEAVY BEATS>> ÃÆâââ€
« Reply #4 on: May 18, 2005, 08:05:50 AM »
Did you try applying some heat to the nut with a torch and then try to knock it loose? Good luck! :)
87 tintop sammi 2" shackles,31/10.50 w/kmc rims,Snorkle,projector headlights,1000 watt sound system,Tweaked ignition,intake,exhaust.
Offline Cwkick
  • 888
« Reply #5 on: May 18, 2005, 08:33:36 AM »
That is what I was talking about.
Cwkick
  • 466
« Reply #6 on: May 18, 2005, 08:42:38 AM »
No I haven't tried that.  I think this splatter is on there really good, I have actually chipped away pieces of it, but the big problem is that it is located right at the start of the threads so I can't get a bolt started.  Hopefully the tap will clean it up as long as I can get it to go in straight.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: May 18, 2005, 08:44:07 AM »
If you try to cut off the end of it with the slag would it end up too short?
« Last Edit: May 18, 2005, 08:46:35 AM by uncivilized »
Offline SnoFalls
  • 1358
« Reply #8 on: May 18, 2005, 09:06:00 AM »
I don't think the threads will be SAE tho ... need metric for these canadian (japanese born) machines ...
Offline Natebert
  • 1098
« Reply #9 on: May 18, 2005, 09:52:27 AM »
Cut a hole in the frame, run bolt back down through the nut!
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #10 on: May 18, 2005, 10:38:49 AM »
At school they use lettuce oil (don't know if this is right but they call it sla over here and it's a green vegetable...) as lubricant, so that wouldn't be so difficult  ;). And I'd say too try it with a tap and I'm quite sure it's metric too.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline mahimahimo
  • 377
« Reply #11 on: May 18, 2005, 12:00:06 PM »
u got weld spatter on ur nuts  :-X  .......... thats gotta be painful  ;D ;D
Offline SuzukHunter
  • 70
  • CAN YOU SEE ME NOW??
« Reply #12 on: May 18, 2005, 12:54:50 PM »
well i am a welder by trade. i would say use a bigger hammer and a sharp small chisel. i know i could get it off this way. oh nent time try shaving ur nuts for that spatter problem (lol). ;D
  • 466
« Reply #13 on: May 26, 2005, 05:39:25 AM »
Finally got around to doing this, and the tap worked great.  And in case anyone needs the information, the weld nuts for a hitch on a 2002 Tracker are 12mm - 1.25 pitch.  This is actually a pretty odd size, I went to 4 different hardware stores before I found one that had the tap and most kits up to 60 - 70 pcs didn't have it either.
Thanks everyone for your help  ;D
