gas mileage??
  • 1729 Views
Offline ajwilson46
  • 22
gas mileage??
« on: January 11, 2012, 07:56:28 PM »
I just put a weber card on my 87 jx with the stock 1.3 and I drove it over the pass and backk on one tank 200+ miles but filled it up again and im NOW at 72 miles at half tank? It seems like if im constantly driving I get 19-23 mpg but when i run to school then 6 hours later come back to run home my guage is lower than when i left it. Tank is dry!!! but if i were to go fill it up it seems as if the guage is always acurate! HELP!! mile counter seems acurate as well
87 Samurai JX Hardtop
87 Jx Soft top
86 JX Soft top
Offline Capt
  • 738
  • 28
Re: gas mileage??
« Reply #1 on: January 12, 2012, 01:12:18 PM »
My 2 ideas on "What's a Happen' Here"!!
1st, if you have the stock fuel pump, the return line is running Warm Gas back to the tank.
      Gasoline is a VOC with a boiling point at 104 degrees, ie. IT EXPANDS LIKE KRAZY !!
      And it contracts like wise. "Different readings after being parked."
2nd, Any fuel gauge is a "Estimator" at best, Also your tank is not of a perfect shape for volume,
       and the gauge "Sender" measures "Fall" from top to bottom. Visualize a Round Fuel tank like on
       a Semi Truck, as the fuel is being used, it goes down slow to the 1/2 way point, then it seems to
       just "DISAPPEAR" in  the lower half. Also at 3/4's, the amount used IS NOT A TRUE 1/4 of the volume.
      This gets many "Truck Driving School Graduates" on their first trip out ! Even new equipment operators will get caught
       Running Out. I have made many a times a "Never Fails Fuel Gauge" to help a NEW GUY OUT...
       A surveyors slat, with 1 inch marking to the bottom of the stick, nothing beats a Gas Tank Dip Stick !!!
CAPT
Offline ajwilson46
  • 22
Re: gas mileage??
« Reply #2 on: January 13, 2012, 10:24:47 AM »
But like I said if I come back to my car how ever many hours later the gauge will be lower. But if I were to go to the gas station right then and fill up The gas gauge would be considered acurate. So Somewhere Sometime while being parked I am loosing physical gas. Like this morning I started her up. Had just under half tank. Drove 10 miles to school. came back 2 hours on my break to get coffe and my guage was now at just over quarter tank. So I drove right to the station and filled it up and It was just over 7 gallons.
87 Jx Soft top
86 JX Soft top
Offline brenzuk
  • 43
Re: gas mileage??
« Reply #3 on: January 13, 2012, 11:55:05 AM »
I have no idea what conditions are where you park but it is easy to siphon gas from a Samurai.  Just a thought.
