bogging down
  • 14 Replies
  • 3991 Views
Offline mahimahimo
  • 377
bogging down
« on: May 24, 2005, 09:15:48 AM »
for some reason lately the beast has been boggen down a little wehn its not completley warmed up ... it will happen from like 2500 rpms it will bog down  till i give it some more gas then it will pick up ...it does it every now and then...any idea?
                                              -mo
Offline Speedracer7c
  • 2210
Re: bogging down
« Reply #1 on: May 24, 2005, 11:14:04 AM »
Have you done a tune up recently?
Offline mahimahimo
  • 377
Re: bogging down
« Reply #2 on: May 24, 2005, 11:57:19 AM »
well i just changed the oil...plug wires... the plugs are bout a year or so...wa else would u recomend to give a changen to?
                                                        -mo
Offline adamd
  • 369
  • sofa king we todd it
Re: bogging down
« Reply #3 on: May 24, 2005, 02:23:12 PM »
pcv valve, air filter, muffler bearings.
'98 kick
3" B/l
30" Mud Kings
Offline mahimahimo
  • 377
Re: bogging down
« Reply #4 on: May 24, 2005, 06:49:32 PM »
well the whole exhaust and header was recentley changed.....the air fileter is pretty new its a cone filter i rigged onto the stock rubber tubing...so how much does a pcv valve cost and u think it would make a big diff? i was thinken bout doin the cap and rotor ...wa u think
                                      -mo
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: bogging down
« Reply #5 on: May 24, 2005, 11:08:37 PM »
...muffler bearings.
Leg pulling alert!
Check all vaccuum lines. A look at the distributor -- especially if it seems to have an oil leak -- would be in order.
Ack
Offline adamd
  • 369
Re: bogging down
« Reply #6 on: May 25, 2005, 12:30:35 AM »
bout 3 bucks? So u don't have an exhaust leak, right?
Is the check engine light on?
'98 kick
3" B/l
30" Mud Kings
Offline Mythose
  • 361
Re: bogging down
« Reply #7 on: May 25, 2005, 03:14:38 AM »
Muffler bearings lmao,
But i would check fuel filter and change the plugs, one round of bad gass one missfire and your plug will never fire the same again.  Cap and rotor ? take off the cap and have a look see at the points think cap and rotor  should cost >30
and i would use NGK  vpower platnium plugs they are a lot more durable then other cheeper brands. "but run bosh in a volkswagon"
PCV , what does the inside of your radiator smell like can you smell gass or oil in the radiator.
maby take off your air filter and get a can of Throtel biody cleaner, or carb cleaner  and  folow the instructions" spray it in the intake while the motor is running.
When all else fails go get a can of SEAFOAM. unplug a main vacume hose and stuffit in the bottle while the motor is idel nd let it suck the stuff up untill the motor dies. wait i think 30 min start her back up agin.  " THIS WILL GENERATE ENOUGH SMOKE TO FILL UP 1BLOCK"
But it cleans all the vacume ports and lines on the motor also foams up in the intake manifold and disolvs the carbon almost instantly.
oh read the instructions first.
my 2 cents worth
Offline Bama_Zuk
  • 17
  • No it's not a baby jeep
Re: bogging down
« Reply #8 on: May 25, 2005, 05:51:18 AM »
I ran out of blinker fluid one time and started runing rough , na just kidding .Go with new plugs to start with(quick & fairley cheep).
Offline mahimahimo
  • 377
Re: bogging down
« Reply #9 on: May 25, 2005, 09:02:07 AM »
Not gonna lie was a little confused wit the "muffler bearings" lol......hmmm..... ill change the plugs and cap and rotor see how much of a diff if taht makes but the sea foam deff sounds like a good idea but i cant find it any where round here.......also the check engine light comes on every now and then but i think the o2 sensor might be bad cause it will go away for about a week at a time if i reset the comp....so im all confused. also not to sure which vacume line to unplug was hopen some one has a pic of which one they recomend. thanx
                                              -mo
« Last Edit: May 25, 2005, 09:07:44 AM by mahimahimo »
Offline bus_driver
  • 479
  • the voices tell me different things
Re: bogging down
« Reply #10 on: May 25, 2005, 01:40:45 PM »
well i dunno about these thing but my wifes corrolla had a bad o2 sensor and when I changed it it ran alot smoother .....they help the ecm keep the correct air fuel ratios so to run efficiently
and change those muffler bearings thye are very problematic
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline SnoFalls
  • 1358
Re: bogging down
« Reply #11 on: May 25, 2005, 02:46:53 PM »
mahimahimo ,
If you get a check engine light, then take it to a parts stroe have em read the code (usually free), and post up the code ...
The code will isolate your problem pretty well (and you know that's WHY it's there).
Some people diss ECM's but when it says code "66" and you look in the book and you have 3 things to check ... that doesn't suc
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: bogging down
« Reply #12 on: May 25, 2005, 08:00:26 PM »
                                              -mo
When my O2 sensor was bad the check engine light stayed on..... only if I reset the ecm by disconnecting the battery it went out but after driving like 20 miles it came on again.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Mythose
  • 361
Re: bogging down
« Reply #13 on: May 26, 2005, 02:00:43 AM »
Also could be a fuel injector, but then you should ahve a dead or half fireing cylendar, can cause the check engin light to come on, and it will report that your o2 sensor is bad, sometimes it can be a fuilfilter or fuel injector. but i have only ever had to replace one Injector, out of all the cars i have worked on. so not likely,  For seaFoam go to NaPa and ask a sales rep, then go to jiffy lube and aske them were to get it, they may know, It is kinda hard to get your hands on
http://www.seafoamsales.com/buy.htm
you want the motor treatment.
Offline zaggy
  • 1134
Re: bogging down
« Reply #14 on: May 26, 2005, 02:21:26 AM »
Bogging when cold sounds like a temp sensor problem.
    I assume that when warm it runs like it always did?
If so it is likely a temp sensor not reading properly and not giving enough fuel enrichment. (if it was a carb it would be not enough choke). I would suggest taking it to your favorite repair shop, leaving it overnight with them so they can scan it during a cold start. That should isolate the problem.
    That's my best "guess"
Zag
