Misfire,Intermittent
  • 2563 Views
Offline Wilnailu
« on: January 22, 2012, 01:46:31 PM »
I have a 1993 sidekick 1.6 16v with 280k miles.ever since Ive owned it has had a intermittent miss in it.I had tried everything mechanical and ignition related electrical to no avail.A friend of mine who is a certified master mech. Suggested replacing the alternator and believe it or not that corrected the problem,something about the rectifier not conv. The output to dc current completely.Never heard of it but it cured the problem,has not missed a beat in two weeks.anybody know about this?  Oh yeah,before it would shock the crap out of me every time I shut it off and closed the door
Re: Misfire,Intermittent
« Reply #1 on: January 22, 2012, 03:24:10 PM »
yep, in the old days if you had a CB radio you could hear them diodes going bad.
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
« Reply #2 on: February 13, 2012, 05:45:29 AM »
Suzuki has a recall notice out on the misfire if I remember right....
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
Offline talonxracer
  • 1284
« Reply #3 on: February 13, 2012, 06:36:11 AM »
Yep I had serious misfires with my 98' sidekick's stock alternator when I got it, swapped it out for a GM delco 12Si 78 amp alt and have not had issue one. The stock alternator has to work hard to cover just the normal electrical demand, add in some tunes, headlights, heater etc and it overheats the poor regulator eventually.
« Reply #4 on: February 16, 2012, 08:31:51 AM »
Interesting.
So was the shock just like a static electricity type of shock?
Did you have the old alternator tested, to see if it tested bad?
« Reply #5 on: February 16, 2012, 10:38:19 AM »
I think that the shock that you get closing the door would be from a seat cover with polyester in it or the type of sole on your shoes and type of sock that you wear.
Offline justzukies
  • 88
« Reply #6 on: February 20, 2012, 02:33:48 PM »
I would like to know if this works for you.  Where to find a GM Delco 12Si 78 amp?.
94 kick 1.6 16V AT 4dr  Calmini 3" lift
Offline justzukies
  • 88
« Reply #7 on: March 08, 2012, 12:57:51 PM »
Am interested in the Delco Remy alternator swap into your Suzuki.  I have a 94 Kick 1.6 16V and would like to do this swap.  Can you give more info on what it takes, ie single wire vs 3 wire, or just the hook up to the Delco.  How does the mount work?  Any info on the Si 78 amp or other swap would be greatly appreciated.  THX
« Last Edit: March 09, 2012, 05:56:21 AM by justzukies »
